'78/'79 dana 60 front drivers side u-bolt ?
got my snofighter 60 into my '85 bronco ...
used the factory under axle spring plates ...
on top of the springs i used the factory plate that has the u-bolts about 3" apart ...
on the bottom the factory spring plate has them about 5 apart ...
in other words the u-bolts, from the side look like an A-frame ...
is this normal or should the u-bolts be further apart on the top?
the top plates were rusted on top of the springs (although they did have the white nylon anti squeak pads) so i assume they came this way?
thanks
thanks
the driver side does look like that because the u bolts have to go over the carrier casting on the driver side. the driver side leafsprings and u bolts are tight up against the diff carrier on this side so they have to be angled like that. if you look on the passenger side u bolts,they too are slightly angled as well.just not as much. all the factory ones i have seen look this way. (i just looked at my truck and they are the same.)
Shouldn't you be wheelin' instead of sittin' at the 'puter on clear 80 degree Sat.?
vic_v8
08-22-2013 05:22 PM
ALBUQ F-1
07-10-2012 11:40 PM
Scout
04-26-2008 06:05 AM
