gas tank filler access
Not sure how your tank looks but I have a 17 gal one from No Limit. I bought the same flap that you have ( I think it is to small ) but changed my mind for now and went with a plywood floor ( $600.00 worth of wood and polished ss setting in the basement ). Made my own opening door over top of the filler (picture in my gallery). It's still a real pain to fill and not spill gas on the wood plus in my case you can't fill the tank and park on a slight grade with out it leaking out the overflow and setting in my roll pan.
So I would mount it directly over the filler neck and be real carefull when filling.
Chuck
Chuck
I went autzone (none at Advance) and got one of the round flaps (like you).. I see yours is without lock.. I need to find one of those.. as I was only able to find the locking version..
it will be fine tho..
I can't tell from your pics, did you router the bed wood to seat the cover flush with the wood?
thanks..
Sam
Chuck
Chuck
if you have a load of stuff in the bed, you can't get gas.. and of course you have to drag the hose over the paint, and then deal with the dripping..
we did this on a prior pickup (66 chevy) to get the tank out of the cab.
Sam
sogath
05-12-2011 06:41 PM
