Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 01-16-2009, 11:15 PM
camodown's Avatar
camodown camodown is offline
Garage is empty, add now
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
Brake fluid level sensor
Hey everybody! I just replaced an ECT today and noticed the wiring harness below my master cylinder was wet and the wetness continues down the shock mount. It seems like brake fluid and the connector from the brake level sensor is damp, as well as the cruise harness, but the nut is dry. The bottom of the master is wet but the tank doesn't look cracked. I couldn't find any place underneath for the master to leak. Does fluid come out of the brake level sensor and how the heck does it come out? I pulled the plug and could get it to slide out...
For some strange reason I have a feeling Ford SHOULD recall these sensors because it seems like these have the same problem as gassers with leaking... I know the diesel doesn't have constant power unless powered on, so I guess if the sensor lights a fire, I'll get roasted instead of my property....
__________________
2002 F-350 Powerstroke 4x4 Crew Long bed All black Lariat custom Cobra cb mount, 05 Mirrors, ZF6 mod, Manual Transfer Case
  #2 (permalink)
Old 01-17-2009, 07:34 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant future
Roland Mueck
Which connector is leaking or wet? I am confused, a bit, by your description. Sounds like you were describing the pressure switch, when you said "nut". That is the one with the 'power', you were referring to. IIRC, the level sensor uses a "ground" to set the light for 'low fluid level'.
Name:  master cyl level sensor.gif
Size:  5.6 KB Level Sensor
Name:  master cyl pressure switch.gif
Size:  5.4 KB Pressure Switch
__________________
Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6 (live tuned), AFE II w/ Pete's Cover, GTP38R w/ Riffraff billet whl & 1.15, 6.0 Techni-cooler IC, Full Force SS Injectors, Stealth HPOP, Fluidampr, Melling M-208, Walbro FP, mueckster Reg Return & Bowl delete, 910 Springs, mueckster 4R100, 4" SS MBRP, 6.0 Trans Cooler, billet 710 cap, Truetrac rear
PAA Member #62
... From Rock to Rocket-- Thanks to the Brotherhood.
  #3 (permalink)
Old 01-17-2009, 07:43 AM
lee231 lee231 is offline
lee231 is starting off with a positive reputation.
Get the sensor replaced. That's the one that ford has had a problem with. On the gassers, it's on a recall because it has power to it all the time even while parked in your garage and has been known to cause fires. On the diesels, no power until the engine is running, thus no chance of fire while parked in your garage and burning up your house or you. HTH's Lee
  #4 (permalink)
Old 01-17-2009, 11:32 AM
camodown's Avatar
Sorry my description was confusing, I was typing and thinking instead of thinking then typing haha. Both sensors are wet somehow, but the only one that can catch fire if it leaks is the pressure switch. I am going to replace both, provided the level sensor even is removable... Just can't figure out how to get it to come out
__________________
  #5 (permalink)
Old 01-17-2009, 10:26 PM
camodown's Avatar
Well, I replaced the cruise sensor, but noticed the bottom of the reservoir was damp and one of the fittings looked to be seeping. Tightened it up, but it wasn't loose. Hope my MC isn't bad. Does the level sensor come off the tank?
__________________
  #6 (permalink)
Old 01-18-2009, 09:05 AM
mueckster's Avatar
Roland Mueck
The level sensor is removable, but does not go into the fluid directly. IOW, the sensor mounts in a pocket under the fluid reservoir. The proximity of the float, when low, to the sensor activates the warning light. If it is actually leaking in this area, it would be the reservoir, or other outside source, and not the sensor.
__________________
Roland-
PAA Member #62
  #7 (permalink)
Old 01-24-2009, 11:21 PM
camodown's Avatar
Well, just wanted to button up this thread. The reservoir was leaking at the black seals only when hot. Master cylinder was replaced, as nobody would sell me the tank and seals... Hope nobody else has to deal with this as it was a pain in the butt. Make sure to check your cruise sensors as mine was leaking as well!
__________________
  #8 (permalink)
Old 01-25-2009, 11:11 AM
mueckster's Avatar
Roland Mueck
Thanks for letting us know the outcome and for the 'heads up'. Sorry you had such a problem with this.
__________________
Roland-
PAA Member #62
Tags
brake, cylinder, f250, fill, fluid, ford, level, master, picture, powerstroke, recall, sensor, switch, taurus, wet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
