Changing the upper (secondary) fuel filter in a 6.0L
#46
#48
#49
I'm on of those poor soles with an upper fuel filter cover on so tight that you can see the cover flex around the socket when you are trying to loosen it. It feels like the center is going to snap right out of the cover (which I do not have a replacement on hand (and, darn, do they really cost $48 like AutoZone says?) I read somewhere on the forum that bleeding fuel pressure off the filter housing will make the cover easier to remove. I haven't found directions on how to do this, nor have I seen bleeding pressure off the upper filter in the protocol. Am I confused? If the cover is really too tight to use a socket, is it likely that an oil filter band wrench will do the job? Thanks
#50
#52
Edited for clarification
Bleeding should not be necessary to make removing the cap easier. This is in answer to the question posed in post #49. If you want to bleed the system, then open the WIF drain on the primary fuel filter first. Not sure if this helps in the least little bit for removing the secondary fuel filter cap, but hey - why not do it first - can't hurt.
Bleeding IS required to ensure the air is removed from the system before cranking. This bleeding is accomplished by multiple cycling of the ignition switch (prior to cranking).
Buy the OEM cap at AutoNation White Bear Lake
(Saw your "never mind" Tim and edited a bit - the editing should help some I believe??)
#54
#55
AutoNation
Why do you recommend them? Do they discount ? Give fast service?
Thanks for your advice on the bleed. The argument was that threads unerring 60pound pressure would be harder to turn
Allan
(Saw your "never mind" Tim and edited a bit - the editing should help some I believe??)[/QUOTE]
Allan
#56
AutoNation White Bear Lake does indeed discount. If you access them through FordParts.com, you get the lowest price and lowest shipping cost.
The upper fuel filter cap part number is: 3C3Z-9G270-AA. $35 at AutoNation WBL.
IMO the reason your cap is hard to turn is most likely because it is an aftermarket cap (but I guess cross-threading is also a possibility). Make sure you lubricate the cap o-ring as suggested above. I use motor oil. Try putting some oil on the cap threads also. If you ran a fuel pressure gauge, you would see that the pressure bleeds down anyway when the engine is turned off.
#57
Allan
Allan
AFA bleeding the fuel system, there simply is no point as it's self bleeding simply by cycling the key 3 or 4 times. There's no way to bleed from the secondary filter housing to the back of the heads, nor is there a need.
darthcasp
02-02-2013 09:51 AM
