S. California Chapter Join Chapter, Leader:
wheel bearings
Old 01-29-2009, 10:41 AM
WideFord's Avatar
WideFord
WideFord is offline
wheel bearings
i think my right wheel bearing is going out. but these were just replace about 10k miles ago. anyone else having this problem. I know what a bad wheel bearing sounds like and my truck is making that sound. could it be anything else.
anyway thought i would pick your brains for a bit
Old 01-29-2009, 11:35 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Dragging brake pads?
How much offset do you have to your rims from stock? The increased offset will contribute to early bearing demise.
Pop
Old 01-29-2009, 11:39 AM
bpounds's Avatar
bpounds
bpounds is offline
Locking hub spindle bearings???
Maybe a U-joint, but they usually sound different.
Old 01-29-2009, 11:44 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Does it sound the same when you are cornering as it does when you are going straight down the road?
Old 01-29-2009, 12:17 PM
Serg450's Avatar
Serg450
Serg450 is offline
thats funny, ask a question and get more questions than answers.
Old 01-29-2009, 12:32 PM
SpringerPop
You're right, Bill. The hub locks themselves have a bearing inside that needs to be occasionally serviced. This one should have been well-lubed when the hub was replaced:
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
but this one wasn't serviced at all
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Something to try...
Pop
Old 01-29-2009, 12:33 PM
SpringerPop
Does it sound the same with the hub locks engaged as when not?
Pop
Old 01-29-2009, 01:36 PM
75F350's Avatar
75F350
75F350 is offline
Something to try...
Pop
There it is, The needle bearings are often overlooked, and will make some noise. They should have been replaced when the unit bearings were done. Be carefull with the o-ring type seal that wil cause some troubles with the ESOF if the truck is equiped.
Old 01-29-2009, 02:14 PM
WideFord's Avatar
WideFord
WideFord is offline
it only makes the sound when i turn left. and the sound seems to come from the right front tire. My 4x4 is tough to disenguage. i have to wait a while for it to fully come off. i do not know how much offset is in the rims. i bought the truck like this. the truck only has 42k on the clock i doubt the wheel bearings should have went out twice already. is there a grease fitting for it that i can just lub up real quick. i dont want to pull those tires off. lol..
thanks for the help guys and keep the info coming
Old 01-29-2009, 02:19 PM
SteveBricks
I hate to tell you this Tony, but you'll have to pull that wheel to grease anything that has to do with bearings. Sounds like the problem needs to be addressed anyway - it won't get any better, and you don't want a failure to leave you stuck somewhere.
Old 01-29-2009, 02:32 PM
bpounds's Avatar
bpounds
bpounds is offline
You cannot grease the wheel bearings, they are permanently sealed. According to that link Marv posted, you can clean and lube the locking hub needle bearings without removing the wheel.
Because it only does it turning one way, kind of sounds like it would be brake related. Sticky pins in the caliper come to mind as a common problem.
Old 01-29-2009, 02:41 PM
WideFord's Avatar
WideFord
WideFord is offline
well i think it is about time for a brake job anyway. i guess i will have to take a look at the bearings and all the jazz while i have the wheels off.
On another note i am having a superbowl party at my place on sunday if anyone is in my neighboorhood feel free to drop by for some beers.
HRTKD
Toy Hauler Towing; Fifth Wheel & Bumper Pull
06-14-2016 08:14 AM
Ford'05HG
1983 - 2012 Ranger & B-Series
05-04-2016 08:13 AM
motochris
1999 to 2016 Super Duty
02-29-2016 11:55 AM
ItsAFord55
11-20-2015 02:24 PM
Dustin_86
General Automotive Discussion
12-24-2005 06:52 PM
Quick Reply: wheel bearings
