Up pipe mod.
Up pipe mod.
How many of you guys here are using a sneaky pipe here on there 05 and up trucks? Did you buy the pipe from elite or did you mod your stock one? Is this very hard to replace? What needs to be removed in order to get to it? Any side effects to doing this mod? Can I leave the EGR valve in and plugged in or I need to do anything else? Thanks for the help guys.
I am running the Elite Diesel up-pipe myself (EGR blocker plate installed), it looks exactly like the factory equipment. Installation takes about 2-3 hours and a second hand to help align the bolts. Leave the EGR plugged in for factory appearance. The EGR is now blocked and no exhaust flow, no cooler failure, no heating issues to the Right head and best of all no more exhaust into the intake manifold clogging up the engine!
Its a START, but as for "no cooler failure", so not true. The cooler is still in tact and completley capable of leaking.. The coolant flow needs to be taken out of the picture to be completley "safe"
Yes true, the EGR cooler still can fail (so can the rest of the cooling system). I have never seen or heard of one to fail after the EGR is blocked at the up-pipe. I have been looking for threads where the EGR cooler has failed after the up-pipe was blocked off, I have not found any, have you found any I would like to read them.
No I do agree that the risk is alot less with the hot exhaust out of the picture. But, when another cooling component fails it doesnt pump coolant into the combustion chambers. IMO its not worth even messing with it unless your gonna do it all. Just blocking exhaust flow is a band-aid at best. Its like changing your oil but not your filter. Yeah its better off then it was but still not done right.
Ya, I agree do the whole delete, I started by doing the up-pipe from elite (strait pipe) in hopes that it would solve my puking problem out the dugas bottle, but I soon discovered that it still pukes. When I took my EGR valve out and looked in the intake, I saw fluid. I assume it's coolant from a cracked EGR. So I ordered the complete bypass from Elite and will install it next week when the ARP's go on...
In your case you already have a problem with the egr cooler leaking, but I think the argument is that if you don't have that problem then the chances of that happening are reduced greatly. Since the hot exhaust won't be traveling through the cooler anymore, the welds that have been cracking should have a lot better chance of holding up, right? At least that what I understand.
For you guys that have just modded the up pipe, did it give you a CEL? I used to unplug the EGR valve but have started plugging it back in after reading more about it. When I did that it never had the light on, it just gave me a code. Didn't know if the lack of any flow through the valve would cause a light. I have an '05 truck if that matters.
Cel
I'm thinking on installing a block off plate sience mine doesn't have the scoop in the up pipe.I've read that some trucks will throw a code with the block off plate.How could I get around this just saying my truck throws a code??? Preferably without a tuner I like the stock power the truck makes.
any help would be appreciated
and let us know what you find out...i'm wondering the same with my 04 and will probably be doing this mod in a week (just the plug).
Yeah and while your at it, change your oil but NOT your oil filter. Could save you $18 on the filter. Yeah its not how it should be done but hey its better then not changing it at all right?
You guys are wasting your time and money with just the plug, but what do I know.
