od button
od button
i need to know who is the meanest ,baddest, most knoledgeable son of a gun on here lol my od button is broke on my shifter is there a way i can get a switch in the cab and spice a wire to it similar to tc lockup mod or ebpv mod i would just like to be able to disengage od thanks sorry im so bad at explainin thangs
I think all you need is a mometary switch. there are three wires going to it but i belive one is just for the light. I belive it works by sendinga ground to the PCM to disingage OD then agian when you reengage it. The best thing would be to get a new button though. they should be easy to get at the junk yard and im not 100% on the way ti works so dont go cutting and splicing wires just yet.
Mine is broke too, there is three wires sticking out. Two of them engage or disengage od, i assume the other one is the light on the button. When i was at the parts house to get a new button they said I had to get the shifter and all. It did not look the same as mine on my truck so i didnt get it. Sometimes I accidently touch two of the wires together and it takes it out of od,then I have to figure out which two it is.
