how to fold up back seat? - Ford Truck Enthusiasts Forums
Old 01-16-2009, 08:02 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
this is for my 95 f150 extended cab. the back seat is the full length bench seat. how do i fold the back seat up? I looked around as best I could,but i couldn't see a latch anywhere. thanks for the help!!
Old 01-17-2009, 05:06 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
If it's the same as my '93, then you pivot the seat cushion forward on the front supports (like it was sticking to your thighs as you stood up), then there should be a small latch on the passenger side of the back cushion to release it to pivot down.
So, looking from one end, it's like this: _/ to \ / to _ / to_ \ to __
Hope that helps.
Jason
Old 01-17-2009, 08:30 PM
jimbo beam's Avatar
jimbo beam jimbo beam is offline
jimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to behold
Just seen this thread, if you haven't figured it out here's a quick video I shot while folding up the rear bench on my 96, should be exactly the same as yours.
YouTube - 96 F150 - folding up the rear bench seat
Basically grab the little loop and tug the rear of the seat bottom twards yourself, push the back on the seat cushion down so it lays flat on the floor. Then on the passenger side wedge your index finger between the seat and cab and lift the little latch up. Once the latch releases the rear of the seat will pop forward a little. Grab the back of the seat and push it down flat onto the floor.
If you have any large items under the rear seat you'll have to remove them so the seat can lay flat on the floor. As you can see from my messy cab papers and such just smush under the weight of the seat, but larger items will need to be removed.
Do rear seat backs fold down ? Pastor Scott 1999 to 2016 Super Duty 5 11-05-2016 10:12 AM
Folding down the rear driver's side seat? EightySecond 2017 Super Duty 23 09-20-2016 09:11 PM
Do my rear seats fold down or just up... GUNNERDOG 1999 to 2016 Super Duty 17 02-15-2011 08:15 PM
Fold-up rear seat 60cents 1999 to 2016 Super Duty 4 08-05-2008 01:11 PM
stupid question about folding down back seat rcsjr4546 1999 to 2016 Super Duty 16 02-26-2008 12:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
