liveling kit question
I am wanting to level out my 2wd truck. I would like to do a 2.5" lift up frount and mabie a 1" in the rear annyways all I am seeing are the soft style lift spacers for our trucks. I was wounderning if I could use a solid lift block for an 05-08 4x4 with minor modifications? also I am assuming that I will have to get some alignment cams to get it back to spec. what is the stock cam? the most i am seeing is -2 +2 would that be enough or is that too much? thanks.
I have a thread on here about this, here is the link:
https://www.ford-trucks.com/forums/8...eling-kit.html
Hope it helps!
Hope it helps!
check out this thread by Matt
edit: darn Matt you type fast
