Can you pull the heads with the engine installed?
Hello,
Two questions:
I'm thinking of buying a f-150, but since I've always done my own service I'd like to know if it's possible to pull the cylinder head on an '09 with the 4.6 liter engine with the engine in the vehicle?
Secondly, I had heard that you couldn't pull the engine out through the top if you needed to remove it. I was told that you lifted the body off to get it out. Is that correct?
I realize that the 4.6 liter needs little service and that they hold up well, but I'd really like to have these two questions answered before I pull the trigger....
Thanks!
Rob
Two questions:
Thanks!
Rob
You dont' have to pull the cab off to get the motor out....and yes...you can pull the heads with the motor in the truck....lots of people have had to do it on the 5.4's and the 4.6's aren't much different...just a bit smaller....
(thats all on an 08...but the underhood space is the same between the two)
Ryan50hrl,
I kind of thought that you might be able to pull the heads with the engine in the vehicle based on a quick observation yesterday, but I do know that the head bolts are quite long.
Thanks for getting back with me. I doubt that if I bought the truck that I would ever need to pull the heads, but it's good to know that it can be done without pulling the engine. My current 4.6 liter has over 200,000 miles on it and has never even had a valve cover off of it.
Rob
Rob
Douglas Pond
Modular V8 (4.6L, 5.4L)
12-01-2015 08:01 PM
Shake-N-Bake
09-13-2012 02:22 PM
Brownbear13
1997 - 2003 F150
04-02-2008 09:54 PM
