When to use Tow/Haul mode - Page 2 - Ford Truck Enthusiasts Forums
Old 02-22-2009, 02:40 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
I know, that was just my lame attempt at humor. I try not to take anything here too seriously.
Old 02-22-2009, 02:54 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Me too! All we need is high blood pressure and more stress than we are provided on a daily basis anyway.
Old 02-22-2009, 04:36 PM
7.3 Rocket's Avatar
7.3 Rocket 7.3 Rocket is offline
7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future
The only thing about T/H is your fuel economy sucks when you're using it.
Dad and I towed a CAT 236B skid back to CT from Ohio with his 06 6 liter DRW F350.
A 236B series II weighs in around 7,000 pounds so I'd imagine a 236B wouldn't be too far off.
The tow/haul was great for highway off-ramps to stop for fuel or anything else. And steep grades were nice too.
As for using T/H mode when towing 500 pounds.
Would you use T/H mode if you had 2 fat friends in the truck? Because that's equal to or greater than 500 pounds of extra weight.
Old 02-22-2009, 05:28 PM
Good point. I don't haul fat friends though.
Old 02-22-2009, 06:04 PM
hanklin's Avatar
hanklin hanklin is offline
Ambassador
hanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputation
No worries here, come on were all like family
Ive got a ques
Ive got a prodigy and don`t know where to mount it,I did search
Hanklin
Old 02-22-2009, 06:10 PM
Just kidding about the fat friends thing. Pete has a good point too. It doesn't make sense to use the T/H mode unless you're hauling or towing heavy. It will keep the RPMs up in order to keep the truck in the powerband and will tend to suck up more go-go juice in the process.
Old 02-23-2009, 02:44 AM
VRC9170's Avatar
VRC9170 VRC9170 is offline
VRC9170 is gaining momentum as a positive member of FTE.VRC9170 is gaining momentum as a positive member of FTE.
The only inconvenience I find with my 99 is that when I am lightly loaded and climbing a hill it has a tendancy to shift down when its not necessary. I guess thats where the DP Tuner would work. Am I correct?
Bob
PS: is it possible to get my user name changed and still keep credit for my posts?
Old 02-23-2009, 02:46 AM
VRC9170's Avatar
I almost forgot I am not on the 99 to 03 forum.
Old 02-23-2009, 01:28 PM
J_E_Summit's Avatar
J_E_Summit J_E_Summit is offline
J_E_Summit has a very good reputation on FTE.J_E_Summit has a very good reputation on FTE.J_E_Summit has a very good reputation on FTE.
Quote:
Originally Posted by powerstroke72 View Post
Just don't use it in the snow in 2wd. Found out the hard way by accident actually. Getting off I-81 on the exit ramp. Kids yelling, dog barking at them, wife talking to me about something. Didn't realize I'd hit the button. Truck downshifted and got reeaallll sideways real quick. I always double check it now.
I second that, coming down a mountain road with two sleds on the back. It decided to downshift at the same time as I touched the brake. I just barely managed to keep it on the road. If there is any chance of ice or snow being on the road, leave it off unless you are climbing a hill, just manually select your gear for breaking.
Old 02-23-2009, 04:41 PM
7.3 Rocket's Avatar
Quote:
You don't use gearing or any type of engine brake/retarder when the roads are slippery.
That's one of the first things drilled into your head when you get your CDL.
When you do that you are braking the tow vehicle, but not the trailer. If it's slippery then the trailer will try to push the tow vehicle. That will cause one of several things. It could cause the trailer to go around and be next to you. That might pull the back of the truck with it and that makes for a bad day.
Or it could cause the trailer to push the back of the truck around and then you've got problems too.
Those are both situations if you've got a bumper-pull. If you've got a gooseneck/5th wheel you could flip it around so that you'd smash the front of the truck on the trailer.
If you use the brakes and have the proper brake controller then the trailer brakes will apply and that will keep the trailer from trying to push the truck around.
Old 02-23-2009, 04:55 PM
J_E_Summit's Avatar
Quote:
Originally Posted by 7.3 Rocket View Post
When you do that you are braking the tow vehicle, but not the trailer. If it's slippery then the trailer will try to push the tow vehicle. That will cause one of several things. It could cause the trailer to go around and be next to you. That might pull the back of the truck with it and that makes for a bad day..
"Two sleds on" means two sleds on the back of the truck with no trailer. You awlays got to gear for the conditions and I have seen brakes overheat and because people were scared to gear down on long descents, it led to a trip to the ER and a totaled vehicle in one case.
Old 04-29-2013, 06:15 PM
keen1093 keen1093 is offline
keen1093 is starting off with a positive reputation.
Still trying to get a straight forward answer since I'm fairly new to diesel trucks.
I have an 02 F250 7.3 Powerstroke. It has rediculous power but I feel like I'm just wasting gas when I tow my boat. It's about 2500 lbs. total. I also have a travel trailer that is closer to 7500 lbs.
From what I'm reading I should for sure use it coming down the mountains (I tow the sierras in CA a few time a year). How about flat ground or going up the mountains (its about a 7400 ft elevation change to the top)?
Am I hurting the tranny not using it?
Thanks, I'll absorb all the rookie comments for trying to get specific answers.
  #28
Old 04-29-2013, 06:25 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Using tow haul changes the shifting patterns. It allows it to stay in gear long to prevent hunting and excessive gear changes which also create extra heat.
For 2500 lbs I would not bother unless going down a hill or steep grade. It will then help to save your brakes from excessive use of that.
For the TT i would use tow haul and leave it on unless conditions are wet.
It does not use anymore fuel as a whole however since it holds the lower gears a bit longer maybe it does. Personally use which one feels better according to the seat of your pants. For me it is tow/haul for anything over about 5K pounds.
  #29
Old 04-29-2013, 06:36 PM
bpounds's Avatar
2 bit Californian
Actually, you don't have tow/haul on an '02. All you have is an overdrive lockout. But the answer is pretty much the same. If your transmission is shifting up and down from OD frequently, use the lockout. On that transmission, I would leave OD off all the time when pulling your heavier trailer. The tranny will run cooler.
  #30
Old 04-30-2013, 08:44 AM
Cruiseomatic's Avatar
Cruiseomatic Cruiseomatic is offline
Cruiseomatic is gaining momentum as a positive member of FTE.Cruiseomatic is gaining momentum as a positive member of FTE.
Wow this is an old thread...I can't believe that my Silverado has Tow/Haul and its an '01 model. How did GM beat Ford to that?!
When to use tow/haul mode tim665214 6.7L Power Stroke Diesel 14 01-13-2017 10:26 AM
Using Tow/Haul Option nygiants4ever Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 01-12-2017 11:27 AM
tow/haul Patrick M 1999 to 2016 Super Duty 29 11-02-2013 02:18 PM
Use tow/haul or not with towing tune? DesMoinesDieselDuty 6.0L Power Stroke Diesel 8 04-25-2012 03:22 PM
Need Transmission Techies Help Jim McCarty 1999 to 2016 Super Duty 5 11-18-2007 09:43 PM
Tags
05, 2006, 2008, 3rd, drive, f250, ford, gear, haul, mode, race, switch, tow, towhaul, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
