You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
i have a 77 e100 van with a 351w i also have a 89 ext cab ranger .the motors bad in the ranger and the vans body has seen its better days,was going to junk both then i thought hummm.thanks for any help.
It should be doable with some parts from an explorer and parts made to do an engine swap from summit racing. I've seen pics of a 460 in a ranger. I'm sure it'll take a little fab too.
__________________
'77 F100 302 C4 John Deere Blitz Black and Cragar Soft 8s
Friend of mine said that Ranger V8 swaps are quite easy, I'm sure the kits make it easier.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
I have not done it yet but am preparing to swap a 351w into my `97 Ranger 4x4. the 5.0/302 swap requires a small modification to the heater box on the firewall, simple motor mount plates, trans xmember and mount, and beating flat the seam where the firewall meets the floor. the 351w is both taller and wider than the 5.0 and i`ve been told that while it might be possible without, a bodylift makes it so much easier. you should use a dual sump oil pan ( so you can mount the motor lower ) from a crown victoria with a351w ( police car? ) the pan is probably available new from ford or the aftermarket. `The Ranger Station` website has lots of swaps, info etc. well worth an hour or 2 of reading. good luck on your project!
