HELP!! No power to radio, windows, or domelight.
Old 01-14-2009, 07:05 PM
zss42002's Avatar
zss42002
zss42002 is offline
My buddy is selling his truck in a couple days and was taking out speakers, afe intake, and satelite radio. I go to start the truck and i have no power to windows, no power to radio and no domelight when i switch it on and off. Dont know what i did but none of this works and everything else does.
I checked all fused all were good. I searched the forum for a solution and they said something about the automatic delay relay and i bought a new one and nothing still. I am not sure what else to do i checked with voltmeter if i had anypower to the window or radio and nothing. But the radios clock works and when i turn on the light it illuminates but doesnt turn on.
Please help selling truck soon and can sell it like this. The truck is a 2002 7.3L Crewcab. f350
Old 01-14-2009, 07:39 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
I would check your fuses again with a mulit-meter for continuity, not just visually.
Look at the Breaker #601 and #102 for the windows
#11 for the radio
#35 and 41 for the dome light problem.
Hopefully, you didn't short something that took out the VSM.
The clock in the radio is powered (standby) with fuse #32 where #11 actually powers the radio.
Old 01-14-2009, 08:03 PM
zss42002's Avatar
zss42002
zss42002 is offline
ok im gonna have to look at these tomorrow as far as the breakers do they just reset?? or do i have to dissconnect batteries for like 5 min to reset them??
Old 01-14-2009, 08:29 PM
zss42002's Avatar
zss42002
zss42002 is offline
ok been reading a little more into this and found that some people have changed the fuse for the instrument panel and it worked so i will do this tomorrow but does anyone have a clue were the battery saver relay is?? i will let you all know how it turns out tomorrow. Thank you.
Old 01-14-2009, 09:55 PM
joeyd61's Avatar
joeyd61
joeyd61 is offline
this is interesting, from time to time my truck will do the same except only for a few minutes(appx 2-5) and then everything will start to work..ie, windows,radio and dome lite
my truck
2003 f 250
237000 miles
cold air intake
bankes power elbow w monster exhaust
preditor programer(changing to DP when taxes come in)
Old 01-14-2009, 10:09 PM
RussB's Avatar
RussB
RussB is offline
I had my radio die once like this as well.... I pulled the deck out and plugged it back in and it worked.... Unhooking the batteries I'm sure would do the same trick.. !! Its worth a shot... Disconnect the batteries if all else fails and let thing reset themselves !!
Old 01-14-2009, 10:39 PM
JockD's Avatar
JockD
JockD is offline
At least on the 2001 pickup, the radio also has a fuse in the battery junction box - #29 - 20 amps.
Both the power windows and the courtesy lights are controlled by the GEM (Generic Electronic Module) mounted on the back of the central junction box. This module grounds the control relays to keep power on after you shut off the key. It also controls everything while the key is on. Even the dome light switch on the light switch uses the GEM to control the dome light.
If you have good power at the fuses, and if you jumper from power to the lights directly and they work, then it looks like a bad GEM.
Jock
Old 01-14-2009, 10:44 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
From the 2002 schematics that I am looking at, the Battery Saver relay (K115) and the Interior lamps relay (K333) are incorporated (or plugged) into the Instrument cluster Microprocessor.
The battery saver relay is protected by fuse 35. The Interior Lamps relay coil is also protected by fuse 35 but the contacts of the Interior Lamps relay that power the interior light are on fuse 41.
The Interior Light relay will not operate unless the Battery Saver Relay energizes (controlled by the Instrument Cluster Microprocessor).
(It was confusing trying to write this, I can imagine what it's like trying to read it!!)
Old 01-14-2009, 10:47 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
I agree but unfortunately beginning in 2002 there is no GEM.
Old 01-15-2009, 02:28 PM
zss42002's Avatar
zss42002
zss42002 is offline
ok changed out fuse number 41 which was blown and everything worked thank you all for your help hopefully this will help others too. Thank you again.
Old 01-15-2009, 05:19 PM
RussB's Avatar
RussB
RussB is offline
Glad you found the problem.. I hate those little electrical problems ! Can be frustrating ! Nice work guys !
Old 04-15-2011, 07:12 PM
freefall_sk's Avatar
freefall_sk
freefall_sk is offline
Question 2003 F250 Electrical
I am also having a similar issue that just started this winter. When my truck is cold inside(below 40 degrees) my check engine light stays on,radio,power windows and wipers do not work. After a few seconds 5-10 you here a relay click then the radio comes on,windows work and check engine light goes off. Wipers will not work until I run the heater and warm up the cab. Can anyone help me with this issue? I have checked all the fuses,wiring,grounds etc. Ford tells me they have nothing on this issue but I have found many posts on different sites. (2003 F-250 Super Duty FX4 4x4 with 5.4lt)
Old 01-22-2016, 09:27 AM
agiient's Avatar
agiient
agiient is offline
Resolved!!
For 2007 Ford F-150 Check and replace fuse #21. This fixed the issue with: No power to instrument cluster, power windows, radio, and all interior lights.
For me, this was caused by trying to replace the map light bulb and shorting two of the band circuits that run to the light bulb.
Old 10-25-2019, 07:44 PM
adrian StarDrift's Avatar
adrian StarDrift
adrian StarDrift is offline
Dome Light
I'm trying to bypass power to dome light, I had a sunroof installed and when they put connection back to dome it shorted and blew those fuses and windows and radio not working. Cant get hack there until late next week any suggestions?
Bmanwplan
1997-2006 Expedition & Navigator
09-08-2021 10:58 AM
Starvega
10-05-2017 02:34 PM
pmcortez
1999 to 2016 Super Duty
01-30-2017 05:05 PM
OnlySS
09-17-2016 05:10 PM
wrhatt
03-30-2016 06:34 PM
Quick Reply: HELP!! No power to radio, windows, or domelight.
