Help with '77 F-150 Posi
I just had a detroit locker installed in mine, I didn't really trust myself to do it but I believe you just need new carrier bearings because you will trash the old ones. And you need your set-up for whatever your going to be putting in there, the locker that was installed replaced all my spider gears but kept my original ring and pinion.
I remember when I was young I had a posi set up put in my car. I stopped at a four way intersection to make a left turn and the road was wet. As I started into the turn the tires started to spin and I went around in a ring VERY fast. If there had been a vehicle setting to my left waiting to go through the intersection I would have slammed into them.
They will also start going side ways on you if your not carful. After I got onto it, it was kinda fun, by the motor was a monster too.
My point is if your not familure with this type of rear it can get away from you rather quick. Just a pearl of wisdom,.............
im pretty familiar with using them and driving them im just not very educated any other options or what i can do cause either way ill need posi in winter and summer for work i think its called a slip lok would that work so both wheels are not always spinning and straining the axle on corners? that way wen i start spinning it kicks in?
7.3stroker2215
03-30-2022 11:58 AM
Blk_smoke
12-05-2010 10:52 AM
jleinweber
05-17-2005 10:18 PM
