Pros & Cons of TireSize Change?
Depends on how you + size the tires
Bigger rims + bigger tires
you will have more sway and instability. this is caused by the increased sidewall. high speed maneauvers should be avoided
braking power will be reduced due to the larger rolling mass and increased wieght
acceleration will be less...same as brakingsame size rubber, bigger rims
same overall handling characteristics as the OEM setup
same rims + bigger tiresbraking power will be reduced due to the larger rolling mass and increased wieght
lower sidewall height, so rims are more likely to get damaged
should retain factory braking/power though
also forgot to mention the rolling resistance that wider tires will cause
so not only do you lose braking power, acceleration...but you also lose MPG since the wider tire has more friction/rolling resistance
but in the end, + sizing tires does look awesome on these trucks...can't wait to get some myself
Last edited by Tylus; 01-14-2009 at 06:25 PM. Reason: my grammer has me sounding like a tard
The only way I know to correct speedo reading for other than stock tires is to install a custom tune that allows such.
Tylus...I disagree a bit on larger wheels, same size rubber...
Larger wheels weigh more, which does do some things to the way it will handle. Increased rotational inertia means less acceleration and braking, as you said for the other configurations, just not as much.
Also, an effect you didn't mention was increased unsprung weight, which is what causes problems with shocks, and a rough ride. If you're looking for a nice ride, lighter is better! Never did find exact specs on how much the factory 20s weigh, but I've heard numerous times that they are significantly heavier than smaller rims....
Took the weight of several 18" rims and the weight of their rubber
then
Took the wieght of several 20" rims and the weight of their rubber (same diameter as 18" rubber)
in most cases, the weights were within 1-5 lbs of each other going from 18" to 20" tires...usually the big wieght differences were with huge gaudy rims. when we are talking about 85+ lb combos...well that few extra lbs of weight is negligable in my eyes
now if you upgrade to + size rims...and then + size the tires...I 100% agree with you.
In my case . I chose to go with the factory steel rims (Winter Months Only) I also went with Cooper M&T 255/60/R17. According to the chart at 60mph I will actually be going 64mph. Stock tire size is 255/70/R17. I am waiting to finish off the oem tires and go with 33's.Yes I have 2.5" leveling kit.
Factory
Winter
Factory
Winter
