Need a relay - Ford Truck Enthusiasts Forums
Need a relay
Old 01-14-2009, 01:01 PM
ScottInTexas's Avatar
ScottInTexas ScottInTexas is offline
Give me coffee - Or beer!
ScottInTexas has a great reputation on FTE.ScottInTexas has a great reputation on FTE.ScottInTexas has a great reputation on FTE.ScottInTexas has a great reputation on FTE.
Need a relay
My truck trailer connection has no power to the + pin, called the Trailer Tow Battery Charge. I traced back to the fuses and relays and discovered the relay missing. Unbelievably Ford is having a hard time with this relay. They don't seem to be sure which one it is. My owner's manual says it is a Full ISO relay. But Ford doesn't like that description.
What can I use there? Is there any after market relay available that would fit. Napa said they don't have anything listed, and O'Reilly and Autozone look at me with a stupid expression. I also need one for the starter relay. Mine was replaced with a anti theft device that has a remote control. I want that removed so I need the realy. All the relays appear to be the same. I plugged in the blower motor relay in the trailer tow charge position and got power to the + pin. But I need the blower motor. The Ford guy said that it might be the right one, but he couldn't be certain and if I plug it in and it doesn't work it's my loss. At $27 to $34 each I want to be sure.
Maybe the parts guru can tell me what's possible.
BTW - This is for the 2006 F-150, 4.6l truck.
Thanks all.
Last edited by ScottInTexas; 01-14-2009 at 01:02 PM. Reason: Clarify which vehicle
Old 01-14-2009, 01:52 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
First of all, this is the 1997 - 2003 F-150 forum. I would recommend that you try a RV shop or Trailer Towing shop in your area. They may be able to help you with the relay. Otherwise try sending a PM to NumberDummy. He seems to know a lot about part numbers in the trucks. Good luck!
Old 01-14-2009, 05:55 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Quote:
Moved to 2004-2008 F-150 forum.
-Matt
Old 01-14-2009, 06:34 PM
dlburch dlburch is online now
dlburch has a good reputation on FTE.dlburch has a good reputation on FTE.
My '08 came with a relay and brake controller pigtail in a plastic bag. The part number on the relay is F0AB-14B192-AA. The part number in the instructions is F0AB-14B192-A (Trailer Tow battery charge full ISO Relay)
The part number for the entire package seems to be 4L3T-15A416-AB
Old 01-15-2009, 05:41 PM
jamesgoodhue jamesgoodhue is offline
jamesgoodhue is starting off with a positive reputation.
The Relay you are talking about is a MULTI RELAY... R01 Thru R06....They are all the same, and yes FORD Dealers are idiots and have no idea how to find them without the part number... Any questions just asked, went thru this for the past 2 months. looking for answers
Old 05-24-2012, 12:28 AM
MonTex MonTex is offline
MonTex is starting off with a positive reputation.
F0AB 14B192-AA is the correct Ford part number for this relay (for my 1997 F150 4x4).
http://www.fordpartsgiant.com/partli...7-1923401.html
Read codes by Malfunction Indicator Lamp PEG 1997 - 2003 F150 6 10-20-2014 12:54 PM
Weird: Hazard / Turn Signal / Heater & AC Control Issue cpye2 1999 to 2016 Super Duty 4 12-27-2013 02:16 PM
1983 E250 Club Wagon 6.9L Diesel Blower Motor issues! LeeTribeRide 1968-2013 Full Size Vans 3 11-09-2013 05:10 PM
1983 E250 Club Wagon 6.9L Diesel Blower Motor issues! LeeTribeRide Cooling, Heating, Ventilation & A/C 0 11-09-2013 01:46 PM
Need part # please The Masked Rider 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-11-2013 05:30 PM
Tags
150, 15a416, 2005, 2006, 4l3t, 4l3t15a416ab, ab, blower, brake, fi50, ford, full, iso, motor, number, part, r06, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
