Duraspark II swap-do I need the voltage reg?
Last spring I swapped a 77' f150 300-6 with Duraspark II in my '60 F100 with original wiring. I made the necessary connections (red to switched hot - to power the 'box', white to S on starter solenoid-to retard timing slightly for easy start). I am having a problem of a dead battery after the truck sits for a few days. This is a new battery that has been back to the parts shack for testing and recharge. I heard from another fella that I should remove the original voltage regulator due to the inline 'regulator' in the alternator. I dont recall reading anything about this when researching the swap...any thoughts or input??? I am in that unique position of justifying the reliability of the truck to keep the Mrs at bay...i.e. I need more money to keep playing!
Thanks,
Ryan
Thanks,
Ryan
None.
With DuraSpark (which was introduced in 1974)...or without it, the same alternator voltage regulator was used from 1965 thru 1983 (1963/83 on T-Birds).
1960's still used a generator, so it would need either an atlernator with a built in regulator, or the fender apron mounted type used previously.
on
What pre 1984 Ford had an regulator attached to the alternator?
None.
None.
Let me clarify, I'm also using an MSD-6A box, so the original regulater mounted on the fender apron next to the horn mounted on the radiator support, becomes superfluous.
sixofspades
33
12-25-2023 10:28 PM
reamer
07-09-2017 12:08 PM
LARIAT 85
38
01-09-2016 12:48 PM
uncle_jessie
05-14-2011 10:02 AM
