Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Pennsylvania Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: Oldtrucknut7077
  #1 (permalink)
Old 01-13-2009, 08:49 PM
sckootter16's Avatar
sckootter16 sckootter16 is offline
Garage is empty, add now
sckootter16 is starting off with a positive reputation.
ok guy hi emmission question
OK I have a 81 f-150 I am rebuilding a 351 winsor no for state inspection the truck it self with the straight 300 6 in has emission crap on it like egr aif pump stuff like that. now for when I rebuild my 351w do I have to get a intake that take a EGR valve and do i have to make sure it has all the emission stuff that cam on the straight 6 goes on the v8?
  #2 (permalink)
Old 01-13-2009, 09:00 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
to be legal yes, to run right, no.
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #3 (permalink)
Old 01-14-2009, 05:58 PM
so what your sayiong is I have to have the emission crap on the truck to get it inspected there is now way I can get around this problem like buying a motor in the early or late 70 ?
  #4 (permalink)
Old 01-14-2009, 06:41 PM
03scf250's Avatar
03scf250 03scf250 is offline
03scf250 is starting off with a positive reputation.
To be legal you have to have what the truck came with for that model year. That is the reason I bought my 78 , no cats and major smog junk. The year of the motor doesn't matter ,truck year does. One way around this is to register classic or antique as they don't reguire emission inspection. Only thing is you are limited to how much you can drive it. Hope this helps.
Where in PA are you from?
__________________
Mike (member of the PA chapter)
2010 F150 sc 4x4 xlt 5.4L
2005 Hd Softail
1999 Explorer (girlfriends car)
  #5 (permalink)
Old 01-15-2009, 06:35 PM
BEAST428 BEAST428 is offline
2003 Ford Excursion
My Garage
BEAST428 is gaining momentum as a positive member of FTE.
Depending on what part of the great commonwealth of Pennsylvania you reside the emission regulations are different. I happen to live in Blair county where as of now the final decision of whether or not your truck will pass ultimately lies with the inspector. Take for instance my 1979 Bronco. This vehicle originally came with a 351M and NO emission equipment. Even though the state says it did. I bought it new and have been the only owner. I have since replaced the 351M with a 71 460 and 2 1/2 inch dual Flowmaster system. I have my PA inspection license but do not issue my own stickers. The shop I take it to states that anything that has under 5000 miles per year is exempt from emission testing. But the state says that to pass the safety inspection a vehicle must have the emission equipment that came from the factory or a proper replacement. The state also says that the original exhaust system (or equivalent) must be used and that the tire size must not be larger than original. Yeah right! If you live in one of I think 5 areas that requires tailpipe testing things are a lot more strict. Also vehicles with classic titles are emission exempt but have restrictions as to modifications and how much you can actually drive your vehicle. You need to check out these before you can change your vehicle to classic status. It is a real bi--- to change it back to normal.
  #6 (permalink)
Old 01-15-2009, 07:43 PM
silver05fx4 silver05fx4 is offline
silver05fx4 is starting off with a positive reputation.
what beast said is right on the money about are great emissions testing ..but the best thing to do is get everthing to make it as it came for that year from the factory ...but im not saying thats all shops fallow all the rules..so look around and talk to a few shop might be able to slip it by
__________________
2010 F-150 STX EXT-CAB BLUE FLAME 33" BFG
prev-2009 F-150 FX4 CREW CAB 3.73 E-Locker,
2005 F-150 FX4 35"edge super 40's http://www.ford-trucks.com/forums/album.php?albumid=485
  #7 (permalink)
Old 01-17-2009, 01:49 AM
well I live in butler county and right now the shops just check if the components are their but they do not have to work but the exaust has to have cats on. right now the truck has EGR valve and a air pump. so what your saying is I have to find a intake that takes a EGR and a carb that eccepts emission crap to.
  #8 (permalink)
Old 01-18-2009, 02:31 AM
F250army45d F250army45d is offline
F250army45d is starting off with a positive reputation.
Going through a similar thing with a 78 F250 I bought from an FTE member in WV. I t had no emissions crap on it except the fuel tank evap canister so the garage looks up the state book for that modle year and all there book said it had cat and smog pump and egr valve. Guy at the gaage says it has to be there but not work. But to get around this I wrote a letter saying I have owned it for a year and put less then five thousand miles on it.
So how can I punch out the cats?
__________________
Mikes Trucks
77 F250 4x4 Highboy FE410
78 F250 4x4 Flatbed 351M to 385
97 F150 4x4 Shortbed 4.2L V6
01 Explorer sport 2 door leather V6
  #9 (permalink)
Old 01-18-2009, 01:29 PM
2003 Ford Excursion
My Garage
It is better to take the cats off before you gut them. That way you be sure no cat guts get stuck in your muffler. Then just use something like a piece of old pipe or someother steel thing (i got a shift lever off an old dodge) and a BFH and start pounding the guts out. Make sure you get them all out and be sure to wear at least a dust mask and safety glasses. cats contain platinum, nasty stuff to get into you. have fun.
  #10 (permalink)
Old 02-18-2009, 04:17 PM
dkstuck dkstuck is offline
dkstuck is starting off with a positive reputation.
eBay Motors: 1973-74 ford maverick/comet carburetor spacer plate (item 310121541363 end time Feb-15-09 19:46:46 PST)
This is how I have the EGR look! Slap on manifold, throw carb on an run a vacuum line to nowhere!
My 78 F150 was over 6,000 (6,040) so I only need ; gas cap check, EGR visual, and Pcv visual. Allegheny county strict laws!
F250army45d, Not sure what he was looking at in book, THAT book is hard to understand, Dig into the book and find all regs for truck with gross weight. Forget about calling PA Hotline, They ARE clueless
  #11 (permalink)
Old 02-18-2009, 06:51 PM
Redcat Diesel's Avatar
Redcat Diesel Redcat Diesel is offline
1996 Ford F-150
My Garage
Redcat Diesel is gaining momentum as a positive member of FTE.Redcat Diesel is gaining momentum as a positive member of FTE.
Grab an instrument cluster at the bone yard. It takes about 15 minutes to swap them out twice a year. " Yes sir, I rarely use it sir, only drive it maybe 1500 miles a year sir ". I ran an 89 Econoline like that for about 5 years. Cat was plugged when I bought it. A new cat cost more than it was worth. Gutted the cats and bought a cluster for $10. Way cheaper.
Ditto on Aggravation County.
__________________
Clay
96 F150, 72 F100, 69 F250, 67 F100
Pennsylvania chapter member
" Don't the girls all get prettier at closing time" - Mickey Gilley
  #12 (permalink)
Old 02-19-2009, 03:27 AM
Yeah lots of things could work and I don't think they no at the garage what the book says or they don't understand it. For now I'm going with the exempt letter then later down the road ill make things right back to factory. I have been looking for parts and found most things new.
__________________
Mikes Trucks
  #13 (permalink)
Old 02-19-2009, 09:20 PM
1996 Ford F-150
My Garage
Quote:
If you're working on emission parts for that highboy in your sig you might want to do some research before you spend any more money. I've been told that any vehicle 77 or older is now exempt under PA law. I got this from a friend who owns a shop that does emission inspections.
I found out about the 77 and older clause when I bought my 72 F100 since it was registered in Allegheny county.
__________________
Clay
  #14 (permalink)
Old 02-20-2009, 04:04 AM
Guess I should add all my vehicles to my sig. I was talking about my 78. And from what I read online at the PA department of vehicles its 76 and older are emission exempt unless they recently updated it in the past six months.
__________________
Mikes Trucks
  #15 (permalink)
Old 02-20-2009, 04:00 PM
1996 Ford F-150
My Garage
I'm gonna do some more reading on that. At the time I got that info I was researching the requirements for antique plates.
__________________
Clay
Tags
antique, cargo, haul, pennsylvania
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
