Snowplows
Snowplows
Ok I know it says we arent suppose to plow with our trucks. But its hard to get a job here in the winter. I just got laid off the other day and I build autoshow displays for a living. So with the car companys going bankrupt who knows how next season will be. We usually work 12 hours right now but we are all layed off. So next season I was thinking about maybe putting a plow on my truck. I was looking at the Snowway plows I think they are called. The series 26. They say they are made for our trucks. I just wana hear if anyone has them on their truck and how they like them. Also what kinda price range would I be looking at for any light weight plow. I also seen alot of people say the only ones that should have plows our xl and xlt with the snow plow prep package. Why didnt the fx4 have that option? Cause thats what I got. Thanks guys
plows
I hear you on that.. I am also in Michigan and it sucks here for work, I am a laid off electrician.. I have been thinking of installing a plow myself. I checked out online Blizzard plows there are a few distributors in Michigan I am closest to dearborn heights shop. These plows are made for 1/2 ton trucks like ours. Hope this helps out SS.
The blizzard is the way to go. I have thought about it but at this point i can't bring myself to put a plow on my pretty truck yet. But my boss has to blizzards on a 3500 dodge and an F350 and these plows are great. On the bigger trucks they extend to 10 feet and they also scoop... Great plow. About 5500 for our trucks.
Mark
Mark
you can put the snowplow on any version of our trucks
all you need is the Heavy Duty front springs...and a 4x4. you'll swap your OEM springs out and the HD springs can take the extra weight alot easier without sagging as much
you're going to eat ball joints up like mad if the plow is connected alot though
Ya im just throwing it out there. I dont know if I want to. It would also be a pain to take off my bull bar and lights every year to put on the plow attachment and vise versa. But it might be worth it. If I do Im leaning towards the Sno-way plow. Its made of polycarbonate so its light weight. Its clear so I think it looks kinda cool. Plus I think I saw on their website somewhere it weighs 450 lbs. Which is like 100 lbs less then all the others I have seen. Might not be a bad plow and it has a down pressure to help clear snow better.
Snowplowing
I use my 06 FX4 supercrew to plow with the Snoway plow -- works great
Truck now has 90K miles and on its 3rd winter plowing.
Nothing ever broke while plowing. Ball joints are fine.
I did add:
1 - upgraded front springs to "U code+ 475 lbs
2 - add a leaf to rear + 800 lb increase
3 - 275 amp alternator & wiring from Nations Starter & Alternator (online)
4 - Sears DieHard Platinum battery (rebadged Odyssey AGM dry cell type 950 amp)
kind of mad a 3/4 ton out of my 150.
I did add:
I did add:
I did add:
I have a SnowWay on my F250 that I have had since 1997. It has been great and I've had no problems with it at all. When I first got it I had a '95 F150 SC Short Bed.. It worked great on that truck. The only thing I changed from stock was I added airbags inside the front coil springs.
I traded for a SD because I bought a Travel Trailer and neede more power. The 150 only had a 5.0.
on
1 Post
My Dad has a 26 Series snow-way plow. It was mounted on his 99 F-150 until my brother totaled it. Now it just sits not being used. But, it worked pretty good. It has the downpressure, wireless controls and the see-through polycarbonate moldboard.
It was actually used commercially. No problems with it at all. Nice little plow.
I have an 8 foot Arctic plow that weighs in around 800 pounds on my 2001 F-150! This is my second year plowing with it and no problems yet. The truck handles it well. I am very impressed.
Just take it easy, don't get reckless and a F-150 is a very capable plow truck. I will say a SuperDuty is better though.
-Matt
-Matt
-Matt
-Matt
Front springs - coilspings.com 785-437-2025 $400
Rear add a leaf - jolietsuspension.com 815-729-0356 $400
Alternator 275 amp - nationsautoelectric.com 888-334-2632 $700 w cables
Plow - Snoway snowplowsupply.com 630-759-1080 $4500 installed
Battery - Sears group 65 platinum AGM type dry cell 950 cca $ 200
Plow makes way more money than I spent. So far its bulletproof
1977f150xlt
16
10-09-2009 01:18 AM
02mudbug
1999 to 2016 Super Duty
01-02-2006 06:18 PM
