New York Chapter Join Chapter, Leader: tiny1
NY Chapter Decal??
Old 02-20-2009, 11:50 AM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Ed, I just edited my post with all of the samples. The poll will be set up once we get narrowed down to a couple of choices.
  #122
Old 02-20-2009, 11:56 AM
spinella's Avatar
spinella
spinella is offline
neil,
whatever you want to do just let me know and if i can help then i will. personally i did'nt think anything i did was ready to be voted on. i'd like to help you make a really good quality image. light a fire under some asses and get some input on what members would like to see. thanks for your help. i got to go back to work. i'll check in later.
-ed
  #123
Old 02-20-2009, 12:29 PM
lenny1carl's Avatar
lenny1carl
lenny1carl is offline
I've changed my mind again......I really am digging #7 but..BUT I'd kill to see it without the Light Blue "dimension" on the circling "Ford Truck Enthusiast(s).
By NO means a critical view of the design by me.....just a thought. Keep in mind I have NO art skills.
  #124
Old 02-20-2009, 12:52 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
If #2 were a good-quality decal, I'd stick it right dead center in my SD's tailgate right where the Ford oval is on the '08-up SD's.
But the font for the "ford-trucks.com" doesn't look right in script.
  #125
Old 02-20-2009, 02:01 PM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Please refer to the number of the image as noted in post #117 where all of the samples are posted together
Carl, I assume that you are refering to #3 in post #117.. correct ??
Here are my favorite ones at this point......
#3 with the speeling corrected for 'enthusiasts'
#13 I like the font and style for FTE, but maybe something a little different for the remaining lettering to make it stand out also.... if possible
  #126
Old 02-20-2009, 02:13 PM
lenny1carl's Avatar
lenny1carl
Yes Neil...it had a different # in an earlier post and I went off that. Apologies.
  #127
Old 02-20-2009, 05:34 PM
spinella's Avatar
spinella
spinella is offline
art,
would the lettering be seperate from the oval. if so gerber machines can print on clear vinyl very well. just like you see on almost all volunteer fire depts. it can get expensive, or you can do that with a printed oval to achive the shadowing and then add cut vinyl for the lettering. i can see putting that on my rear cap/cab window. it might be a little much for me on the tailgate 20" 's away from my factory emblem.
-ed
  #128
Old 02-20-2009, 05:39 PM
spinella's Avatar
spinella
spinella is offline
carl,
i like this one also. i will remove the perspective shadow and repost it. keep the constructive critism coming. its the only way we'll hash out a cool sticker.
-ed
  #129
Old 02-20-2009, 05:46 PM
spinella's Avatar
spinella
spinella is offline
neil,
first off, glad to see i'm not the only one with a speeling problem.(look at #3). like i said before i like #3. i think it could be a nice window sticker.
#7 i don't care for.
#13 i will make some changes and post.(or really you will. thanks again)
-ed
  #130
Old 02-20-2009, 06:21 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
PETE'S_6.0PSD is offline
im going to work on it, the font got messed up between programs i tried so ill give it another go over the weekend and see what will come out of it.
BTW im glad you like it.
  #131
Old 02-23-2009, 08:42 AM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Okay folks... here are some new samples and a couple of reworked ones for comments along with the original 14 that are posted together.
Thanks Ed
Old 02-23-2009, 11:18 AM
spinella's Avatar
spinella
spinella is offline
thanks for posting those for me neil. i was thinking that on #16 the color of N.Y. can match the color of your truck.
-ed
  #133
Old 02-23-2009, 12:13 PM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
-ed
Yeah I was thinking the same thing so all that it will need is to be a little darker red.
Ed, could you whip up one with the text for #18 to match the text on #16 ??
  #134
Old 02-23-2009, 09:14 PM
spinella's Avatar
spinella
spinella is offline
no problem. i just walked in from my night job, so i'll do it tuesday night and foward it to you.
-ed
  #135
Old 02-24-2009, 08:25 AM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
No problem
Quick Reply: NY Chapter Decal??
