Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > British Columbia
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: Zip
  #1 (permalink)
Old 01-12-2009, 09:06 PM
madone04's Avatar
madone04 madone04 is offline
Garage is empty, add now
madone04 is starting off with a positive reputation.
Cool auxiliary idle control
Hello I am looking for info on the auxiliary idle control system,
I just purchased one and it did not come with a wiring harness, my local dealer says i have to purchase the whole unit from the to get the harness, but I don't want to spend $1300 bucks one just for the harness, so I am wondering if anyone knows where I might find one,or if someone can give me a layout of the harness so I can build one, mine is full function for an 03 f350 6.0 psd
Thanks in advance for any info that may be available.
Mike
  #2 (permalink)
Old 01-12-2009, 10:11 PM
Vinford's Avatar
Vinford Vinford is offline
1979 Ford F-250
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
I see them on Ebay sometimes.
Maybe you can buy the whole thing with harness cheap?
I had a guy give me one but I gave it away.
__________________
Ken
2002 F-350 4x4
Foil delete ,Muffler Delete, Edge Evolutio
1996 F-150
1999 F-350 dually 4x4
Plus a few more .................
  #3 (permalink)
Old 01-12-2009, 10:47 PM
madone04's Avatar
That's where I bought this unit... didn't realise that there was no wiring with it
  #4 (permalink)
Old 02-01-2009, 01:17 AM
Flatdeck's Avatar
Flatdeck Flatdeck is offline
Flatdeck is gaining momentum as a positive member of FTE.Flatdeck is gaining momentum as a positive member of FTE.
It'll probably be cheaper for you to buy another one with a harness... I bought 2 from eBay, for $35 and $40 each, incl harnesses. They didn't come with the brackets, but a buddy is an aluminum fabricator so he's going to build me a custom console for the AIC and a VHF radio.
__________________
Greg :: PAA#55
1999.0 F-350 4x4 PSD SRW reg cab, auto, manual xfer case, Warn manual hubs, aluminum flatdeck, VB springs, Predator tuner, 6637, LT285/75R16E Duratracs, 2003 40/20/40, 2005 cupholder, 2005-07 front end, Sirius Starmate 3
  #5 (permalink)
Old 02-01-2009, 09:49 PM
FlyCanadianGuy FlyCanadianGuy is offline
FlyCanadianGuy is starting off with a positive reputation.
Mike
My work truck has it installed, i'll follow the wiring on Tuesday when im in the shop and let you know. I believe (but could be wrong) that it is simply run straight to the PTO wire under the dash and the resistance in the switch you have determines your RPMs. I will check it out Tuesday, be patient. BTW, how much was your switch?
__________________
'05 F-350 6.0L CC Lariat
6" Rancho Lift
ARP studs
Full EGR delete
MBRP Turbo Back
Learning from the best. You Guys!
Tags
aux, auxiliary, auxillary, conrol, control, controller, ford, harness, idel, idle, module, service, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
