Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-12-2009, 03:10 PM
BREZH BREZH is offline
BREZH is starting off with a positive reputation.
High Boost and other percieved problems after reflash
I originally had my truck reflashed (the day before it was suspended) and then again the week it was re-instated. I also had the tee recall, fuel tank bracket recall and seat recall done at the same time.
Now the IC does display the regen as I would expect, so I know that the re-flash did something. Also the shift pattern has changed and the cruise resume works correctly.
Since having the original re-flash done, the truck is lacking power, the turbo boost runs at ~28lbs at 75 mph, the exhaust smells (and not a good diesel smell), and my mileage has dropped by about 5 mpg. Also, it just sounds like the truck is struggling going down the highway (empty). Lots of noise, hard to describe, but like the fan was running extra hard. So far the tailpipe is not discolored, and it doesn't appear to be any exhaust leaks. Also, I have checked over the air lines going to the cooler and back and I don't see any leaks. Oil appears fine, fuel filters were just replaced and air filter checked.
The local dealer says there is nothing they can do since there are no codes. Is there anything I can steer them towards?
08' F-250, 6.4l, Job 1, SRW, Automatic
  #2 (permalink)
Old 01-12-2009, 03:24 PM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
I have a bit more boost right now but think it is due to the colder temps, but I don't have any of your other syptoms.
I think as the weather warms the boost will back off a bit.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #3 (permalink)
Old 01-12-2009, 03:40 PM
jarez mifkin jarez mifkin is offline
jarez mifkin is starting off with a positive reputation.
I've also noticed higher boost and the shift pattern changed as well after the reflash. I've only driver 180 miles since it was done so I can't comment on mileage yet. I'll update my post in a couple of days.
  #4 (permalink)
Old 01-12-2009, 05:13 PM
Bowstring Bowstring is offline
Bowstring is starting off with a positive reputation.
Had the reflast today fill up before leaving drove 184 miles round trip at 60 to 65 mph filled after returning home took 10.5 gallons = 17.52 mpg dash meter was showing 18.2 no different in boost.
__________________
2008 F350 FX,6.4PSD,AUTO,4X4,SC, TRADED 2000 Lariat LE Quad Seats, F350 7.3PSD AUTO CC DRW 4X4, 4" exhaust , AIS, ISSPRO pillar,pyro,boost,tranny gauges, 6.0 tran. cooler
  #5 (permalink)
Old 01-12-2009, 06:05 PM
thatsme's Avatar
thatsme thatsme is offline
1969 Mercury Cougar
thatsme is starting off with a positive reputation.
I to have a little higher boost. I agree with others it is due to colder air. No other problems at this time. Just recieved my letter about reflash today. Will wait to see how it goes with other folks who have it done.
__________________
08 F-350 DRW 4x4 CC 6.4 Black on Black.
99 F-250 SRW 4x4 x-cab w/Western 7.5 Pro-plow
  #6 (permalink)
Old 01-21-2009, 03:50 PM
BENSFORD BENSFORD is offline
BENSFORD is starting off with a positive reputation.
I to took my truck in for the reflash and my boost is higher now than before. I took a test drive before taking my truck in so that I could tell if the boost was higher or not.
  #7 (permalink)
Old 01-22-2009, 04:14 PM
richfaa richfaa is offline
richfaa is starting off with a positive reputation.
Had the reflash done last friday.I was told that the PC would have to relearn the shift patterens and it did. I note no other problems and the MPG is a bit better. Mine is a early job 1 build...2/07
__________________
..F-350 6.,CC,LB, 4X4 off road, dually, camper package, snow plow package. 4:10LS. Uswed to tow a 14K plus 5th wheel.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
