Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2009 6.4L Power Stroke Diesel
2008 - 2009 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-12-2009, 11:22 AM
kane gray's Avatar
kane gray kane gray is online now
kane gray is starting off with a positive reputation.
Question Engine blow-by question???
I have asked this before on another forum, but didn't really get any answers. I sort of have a favor. My truck has, what I would call a fair amount of blow-by. It is an 08 6.4, maybe 2-3 times more than my 6.0 had. It is enough that if I set the oil cap loosely on the filler, and then rev it it blows off. At idle it wisp's out a fair amount as well. Would anybody mind checking to see how much blow-by comes out of your oil cap? I thought it was supposed to be a tiny amount, like my 6.0 had. Just trying to find out if there is a problem.
Thanks..
  #2 (permalink)
Old 01-12-2009, 07:53 PM
WH90's Avatar
WH90 WH90 is offline
WH90 is starting off with a positive reputation.
I wouldnt think thats good i own a 7.3 and mine does it because someone abused my engine. If it puffs like a train your engine is eventually going to fail and loose compression. I would try to get ford to replace it if i were you
__________________
Wesley Hoffman
Computer Diagnostics Technician 101
2001 F250 XLT Super Duty 7.3 PSD – In Loving Memory of Mike Morris
2003 F250 Lariat Triton V10 4x4
  #3 (permalink)
Old 01-13-2009, 12:26 AM
kane gray's Avatar
Quote:
So I can't believe that I would get a truck with a bad engine already! Is it possible that since my truck has the oil separator built in, that it all comes out there, and none through the intake????? Thanks
  #4 (permalink)
Old 01-18-2009, 11:53 PM
kane gray's Avatar
Am I really the only one who has noticed blow-by out of my 6.4?
  #5 (permalink)
Old 01-19-2009, 05:54 AM
ruschejj's Avatar
ruschejj ruschejj is offline
2008 Ford F-250
ruschejj is starting off with a positive reputation.
The idea of taking the oil filler cap off of my engine while running seems highly unusual and I think that nobody would do that, so the blow by, if it exists is something that none of us would discover.
I might try it some time and i'll let you know.
  #6 (permalink)
Old 01-19-2009, 12:44 PM
kane gray's Avatar
Actually, I thought that was a common way to check blow-by?? The reason I checked it on my new truck, is because I was curious to see if it had as much as my 6.0 did, and it had more, so that's why I asked this question. It doesn't seem right, but I was thinking that the 6.4 might run on less compression or something.
  #7 (permalink)
Old 01-19-2009, 01:50 PM
caprang's Avatar
caprang caprang is offline
caprang is starting off with a positive reputation.
I know every engine has a degree of blow by, thus the reason for a PCV system. I havent made it a practice to compare blow by between engines by removing the oil cap and with the sophistication of today's engines Im not entirely sure that is an accurate measure of "blow by". These new engines are designed to burn and reburn in the name of emissions. On a gas engine I know crankcrase pressure (which is really what you are experiencing by removing the oil cap) can be altered by the size of the camshaft, the amount of vacuum, whether you run a breather or a PCV system, etc, etc.
I think if you have a true blow by issue on your 6.4 you will experience low boost and/or poor performance. As your boost builds your blow by would get worse and at full boost your crankcrase pressure would be so great that you would be ingesting oil in to the system and probably smoking.
One of the performance tricks on 7.3's and 6.0's is to re-route the blow by tube to the rear of the truck rather than it being fed back in to your intake. I believe there are more in depth threads on this in the tech section of both the 7.3 and 6.0 forums that might provide you with more details pertaining to your concern.
__________________
2008 F350 CC 4x4
Harley Davidson 6.4 PSD Auto
Job #3 build, 2" leveling kit, rear air bags, smoked cab lights and mirror lenses
  #8 (permalink)
Old 01-19-2009, 02:37 PM
kane gray's Avatar
Thanks for the info!
  #9 (permalink)
Old 01-19-2009, 10:10 PM
UGA33's Avatar
UGA33 UGA33 is offline
East Bound & Down!
2006 Ford F-250
UGA33 has a good reputation on FTE. UGA33 has a good reputation on FTE.
I checked this on my buddies 08 today when i did his oil change for him. It was the exact same amount of blow-by my 6L emits.
__________________
2006 F-250 Lariat FX4 CC/SB
*6L Power Stroke-SCT X3
*MBRP Exhaust-Autometer Gauges
*Coolant Filter-High Idle Mod-Leveling Kit
  #10 (permalink)
Old 01-19-2009, 10:44 PM
kane gray's Avatar
How much is that??? Is not enough that you can see it coming out a lot? Or just whisping out a little. I was thinking that the oil separator on the 6.4's might be what makes mine smoke more.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
