Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-12-2009, 11:09 AM
grider grider is offline
grider is starting off with a positive reputation.
squeaking belt on 6.4
hello everyone,
i have an ongoing problem with my belt on a 2008 F350 6.4 liter diesel.
when the engine is running there is an aweful squeaking from the belt. someone suggested to spray some belt dressing on the belt to rule out any pulley bearings.
when you spray the belt dressing on the back side of the belt ( the smooth side) the sound goes away, but only for couple hours then comes back.
the dealer has changed the idler pulleys and the belt at least 3 times. since im out of warranty now i have replaced the them aswell only to last couple thousand kilometers then its back.
when seems odd to me is if you look at the back (the smooth side)of the squeaking belt it has a metalic shine to it, the only thing that the smooth side of the belt runs on is the two idler pulleys and the tensioner....
does anyone have any suggestions or has seem this before?
im just at a loss, truck sounds soooooo bad
thanks for any help
  #2 (permalink)
Old 01-12-2009, 12:20 PM
jmcbrid jmcbrid is offline
jmcbrid is starting off with a positive reputation.
I had/have the same problem - seems many do. I had mine to the dealer last year and first had the idler pulley replaced. That did not solve the problem until they replaced the belt. That fixed it until a couple weeks ago (almost a year later) when it started again when the temp gets into the low 30s - the difference now is that it is not very loud and only lasts about a minute or so. Last year prior to taking it to the dealer I did the following --
- Putting water on the belt immediately stops the noise, but doesn't last
- Belt dressing made mine squeal worse
- I even put sand paper against the belt while running - thinking if I roughed it up it would stop. Nothing worked until the belt change, but even that was not an actual fix.
There is a dealer broadcast (maybe a TSB) regarding this that basically states no known fix and to the dealer - do not attempt to fix.
  #3 (permalink)
Old 01-12-2009, 12:27 PM
the last think that i did to mine was a new belt that stopped all and any noise, but it only lasted about 3 or 4 thousand kilometers, now the squeaking is starting again, not too loud yet.
i did the same thing you did, thinking roughing up the back side with some steel wool would help but it didnt,
it gets expensive to keep putting new belts on every couple thousand kilometers
  #4 (permalink)
Old 01-13-2009, 11:52 AM
DesertRider's Avatar
DesertRider DesertRider is offline
DesertRider is starting off with a positive reputation.
I have a similar problem. My belt squeals once in a while when I start the truck, but only for a minute or so. But the worse thing is when it's hot, it squeals much more. Once when I was climbing a grade with my trailer the engine started to heat up. I've never seen the temp gauge budge before this. I turned off the A/C and the temp went to normal. When I reached the summit I turned the A/C back on. The belt squealed constantly and sounded like it was going to break. It didn't appear like the A/C was working, but I didn't leave it on very long. When I turned the A/C off, the noise stopped. I parked in a campsite and over an hour later I still could not turn on the A/C without the noise. I thought the A/C pump was frozen. The next day, everything worked OK, but I still hear the squealing noise occasionally, but it doesn't last long.
I'm taking the truck in for the radiator TSB next week, and I'll see what the dealer will do about the belt or A/C pump
__________________
08 F450 Lariat 4x4
  #5 (permalink)
Old 01-29-2009, 07:51 PM
CT-FREESKIER CT-FREESKIER is offline
CT-FREESKIER is starting off with a positive reputation.
i have a problem on my 08 f250 6.4 (still new with 2000 mi), however i am not sure if it is directly related to the belt or idler pulleys. when applying throttle, even just for a second or two, then let off, there is a awkward muffled rubbing sort of sound that is not constant; after immediately letting off the throttle the sound occurs in intervals that decrease with the rpms. Does anyone know what could be the source of the sound or has anyone experienced it before?
  #6 (permalink)
Old 01-30-2009, 09:02 PM
jiggy jiggy is offline
jiggy is starting off with a positive reputation.
hey ct-freeskier,
have you tried honking your horn 6 times and doing the rain dance? It worked for me.
  #7 (permalink)
Old 01-30-2009, 10:29 PM
rebelyell618's Avatar
rebelyell618 rebelyell618 is offline
rebelyell618 is starting off with a positive reputation.
i believe goodyear has a gatorback belt for your truck, maybe that will get the squeak out of it. 20-30 bucks for the belt.
__________________
2000 Ford F-250 Crewcab Shortbed 4X4 5.4, 4.10 gears
stock height (for NOW), T3 grille guard with hella lights, cherrybomb extreme muffler, cb and satellite radios, many minor mods with more be putting on everyday.
  #8 (permalink)
Old 02-03-2009, 10:36 PM
Greyman's Avatar
Greyman Greyman is offline
Greyman is starting off with a positive reputation.
Just had my idler pulley replaced to combat the squeaking, dealer said truck was done. When they pulled the truck around it was still squeaking. Driver went and got the service writer and he said that he could hear it all the way back at his desk. I told him to call me when they decide what the next step is. Maybe another pulley and a new belt? Do you think it's just the belt or maybe both? Thanks in advance.
  #9 (permalink)
Old 02-04-2009, 09:16 AM
rmosso1's Avatar
rmosso1 rmosso1 is offline
rmosso1 is gaining momentum as a positive member of FTE. rmosso1 is gaining momentum as a positive member of FTE.
Much like a guitar. I would check the tension first. Too little or too much should make a noise.
__________________
2001 Excursion Ltd. V-10 (the GOOD)
2003 Excursion Ltd. 6.0 (the BAD)
2005 F-350 6.0, KR, long bed, 4x4 (the UGLY)
2008 F-350, 6.4, KR, long bed, 4x4 (LEAN, MEAN & BEAUTIFUL)
  #10 (permalink)
Old 02-04-2009, 12:43 PM
caprang's Avatar
caprang caprang is offline
caprang is starting off with a positive reputation.
Courtesy of Maxium4x4 from another post
TSB
07-23-9 6.4L DIESEL - COLD WEATHER BELT CHIRP
Publication Date: November 9, 2007
Figure 1 - Article 07-23-9
PART NUMBER PART NAME
7C3Z-8678-B Kit - Idler Pull
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
072309A 2008 F-Super Duty 6.4L: Replace The Idler Pulley, Includes time For Upper Fan Shroud (This Labor Operation Is All Inclusive, Additional Labor Operations May Not Be Used) 1.7 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
8678 42
FORD 2008 F-Super Duty
ISSUE:
Some 2008 F-Super Duty vehicles equipped with a 6.4L diesel may experience a belt chirp when initially started following a cold soak.
ACTION:
Replace the idler pulley following Workshop Manual, Section 303-05. (Figure 1)
__________________
2008 F350 CC 4x4
Harley Davidson 6.4 PSD Auto
Job #3 build, 2" leveling kit, rear air bags, smoked cab lights and mirror lenses
  #11 (permalink)
Old 02-04-2009, 10:29 PM
Greyman's Avatar
That's the TSB they just did on my truck, calling them tomorrow and asking for another pulley and a new belt. Hopefully this will end the dying bird under my hood.
  #12 (permalink)
Old 02-04-2009, 10:43 PM
my truck is out of warranty now so i bought both idlers and changed them out, the squeaking was gone, 2 days later it started again and got progressively worse.
then i bought another new belt, put it on and the noise was completely gone. that lasted couple thousand KM now its starting to come back again.....
it squeaks when you start the truck, it squeaks after the truck has been running for many hours, the other day after a 1600km trip continous driving the squeaking was gone.next morning its back and never goes away....... how do i know if the tensioner has too much or too little tension?
Tags
20082009 , 64 , belt , chirp , f350 , ford , idler , pulley , squeaking , tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
