Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
is this a easy swap?351w n2 89 ranger
Old 01-15-2009, 05:42 AM
fmb94's Avatar
fmb94
fmb94 is offline
Smile is this a easy swap?351w n2 89 ranger
i have a 77 e100 van with a 351w i also have a 89 ext cab ranger .the motors bad in the ranger and the vans body has seen its better days,was going to junk both then i thought hummm.thanks for any help.
Old 01-26-2009, 04:53 PM
jsutton's Avatar
jsutton
jsutton is offline
It should be doable with some parts from an explorer and parts made to do an engine swap from summit racing. I've seen pics of a 460 in a ranger. I'm sure it'll take a little fab too.
Old 01-26-2009, 06:51 PM
fellro86's Avatar
fellro86
fellro86 is offline
Friend of mine said that Ranger V8 swaps are quite easy, I'm sure the kits make it easier.
Old 02-25-2009, 03:14 AM
OrFordGuy's Avatar
OrFordGuy
OrFordGuy is offline
It is depends on Ac/non-ac and willingness to modify, i.e. cut grind etc.
Old 02-26-2009, 01:59 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
its not too hard...
Old 03-15-2009, 12:31 PM
untrucker's Avatar
untrucker
untrucker is offline
easy swap?
I have not done it yet but am preparing to swap a 351w into my `97 Ranger 4x4. the 5.0/302 swap requires a small modification to the heater box on the firewall, simple motor mount plates, trans xmember and mount, and beating flat the seam where the firewall meets the floor. the 351w is both taller and wider than the 5.0 and i`ve been told that while it might be possible without, a bodylift makes it so much easier. you should use a dual sump oil pan ( so you can mount the motor lower ) from a crown victoria with a351w ( police car? ) the pan is probably available new from ford or the aftermarket. `The Ranger Station` website has lots of swaps, info etc. well worth an hour or 2 of reading. good luck on your project!
Fitzgerald_welding
10-02-2019 01:56 PM
97Fordf35089f250
Engine Swaps
17
02-08-2016 02:14 PM
tomboy67
New Member Introductions
11-22-2014 08:38 PM
79-150ranger
10-01-2012 05:21 PM
yoda_campbell
02-21-2010 10:15 PM
Quick Reply: is this a easy swap?351w n2 89 ranger
