Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-11-2009, 10:36 PM
fpoitra fpoitra is offline
fpoitra is starting off with a positive reputation.
Help Me Decide!!
I need help! I am going to bite the bullet and get an 09 F-150 but can't decide between two that I narrowed down at a local dealership. They are identical XLT's with all same accessories, one silver the other blue flame. Here is the the only difference: Silver has 3.31 non limited slip axle and the blue flame has 3.55 limited slip option. I tow a 1,500 pound trailer with ATV once in a blue moon. Will I get better mileage with the 3.31's, but will it search for power alot? I live in ND, so would the 3.55 limited slip be an advantage in the snow/ice? The salesman said that the non limited slip should be ok with the advanced track that the truck has. I'm not sure if he is correct. That is why I need all or your expertise. Thanks and much appreciated!
  #2 (permalink)
Old 01-11-2009, 11:05 PM
One thing to point out: Do the limited slip axles work on Fords as inteded? I keep reading posts where people are complaining about the LS. My 07 F250 don't work that great either. Believe me, I tried them out on many occasions. Or am I just trying to convince myself to get the 3.31's?
  #3 (permalink)
Old 01-11-2009, 11:25 PM
crabhab's Avatar
crabhab crabhab is offline
crabhab is starting off with a positive reputation.
Ford LS clutch disks wear out fast. I would also assume that both trucks are 4wd? In ND I would hope so. I have had two late model 2wd trucks and took a real beating on trade in last may to get a 4wd. Not going back to 2wd anytime soon, and I am in MD's eastern shore which gets almost no snow. I like to drive on the beach though.
__________________
2008 Ford F-150 XL CC, 4.6, 4x4, 6.5 bed, 3.73 LS
2008 Kia Sedona LX
Ford Truck I have owned:
1995 F-150 XLT RC, 5.0, 4x4 8ft bed, Auto, 3.55 LS
2004 F-150 XL SC, 4.2, 4x2 6.5 bed, Auto, 3.55 Open
2006 F-250 XLT CC, 5.4, 4x2, 6.5 bed, Auto, 3.73 LS
  #4 (permalink)
Old 01-11-2009, 11:34 PM
fordtruckman's Avatar
fordtruckman fordtruckman is offline
2004 Ford F-150
My Garage
fordtruckman has a good reputation on FTE. fordtruckman has a good reputation on FTE.
Well how often do you tow? I truly think you will be fine with the 3.31 and will end up getting better gas mileage in the long run.
__________________
Matthew | 2004 Ford F150 STX | 2007 Ford Fusion SEL | Michigan Chapter member | "Snow Plowers" member
  #5 (permalink)
Old 01-11-2009, 11:58 PM
In a year, I tow maybe 5 times max at 1500 lbs. It is the traction that I am most concerned about. Will the non-limited slip 3.31's suck in the snow and ice, which I drive on 6 months out of the year? Or will the advance trac kick in and get me going without having to put in 4WD everytime I get in some snow or icy situations? Is the advance track like traction control?
  #6 (permalink)
Old 01-12-2009, 12:04 AM
1 more important tid bit: I commute about 40 miles per day. Will the 3.31 save me MPG?
  #7 (permalink)
Old 01-12-2009, 07:23 AM
96sherm's Avatar
96sherm 96sherm is offline
play sumthin country!!
96sherm has a good reputation on FTE. 96sherm has a good reputation on FTE. 96sherm has a good reputation on FTE.
keep in mind that a higher gear rear end will give you worse mpg in city driving conditions. 3.55 is a great gear. it's not that bad for mpg, you can still tow something with it, and it shouldn't "gear hunt" in highway conditions as much...
__________________
Canada
2008 F150 SuperCrew XLT 4x4, 5.4L 6.5ft box.
  #8 (permalink)
Old 01-12-2009, 07:46 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE.
If your gonna get one of these two trucks, I would opt for the 3.55 LS truck. As stated before, great overall gear. I currently own a LS truck and it still works fine after 21 years. I've also owned reg axle trucks and engaged the front axle when I needed more traction.
Tim
__________________
SCPO United States Coast Guard Retired
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
  #9 (permalink)
Old 01-12-2009, 09:18 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
Get the limited slip....granted it doesn't work as well as i'd like it to (read be a full locker) but its for sure better than an open diff in the snow.....you'll wish you had gotten the ls if you don't....
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #10 (permalink)
Old 01-12-2009, 09:36 AM
With the 3.31's, won't the advance track help alot though?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
