Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
  #1 (permalink)
Old 01-11-2009, 09:40 PM
idelatorre idelatorre is offline
idelatorre is starting off with a positive reputation.
Question Issue when installing power steering pump pulley
Hi All!
I learned more about mechanics today than in my previous 28 years of life! I took off and replaced a worn belt and drove to autozone to pickup a new pulley and the pulley puller. After a lot of effort taking the old pulley off (glad I did this at home and not in the parking lot), I spent about three hours trying to push the new pulley in, after all this time I realized that the bolt won't lock into the shaft of the pump, do you think I'm doing something wrong? or could it be that the threads inside the shaft are damaged? Is there a way around if that happens to be the case?
Thanks a lot!
  #2 (permalink)
Old 01-11-2009, 11:53 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Are you sure you have the right thread bolt ?
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 01-12-2009, 08:14 AM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
If you think the threads are damaged you can run a thread cleaner down it.
Make sure it has the same threads as the original bolt.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
