Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-11-2009, 09:18 PM
dantsg dantsg is offline
Dan
dantsg is starting off with a positive reputation.
Head Liner
I pulled the headliner out of my 98 F150 and pulled the material off to replace it. The problem I have is the material came off but all the padding stayed on. Does the padding/foam backing have to come off before applying the new headliner or can I spray/glue the new one to the old padding? I checked the entire board and cannot find anywhere it is loose or frayed.
Help
Dan
__________________
Dan S Miami Lakes, Fl
1998 F-150 XLT 4X4 5.4 Automatic
Cold air Intake/ Dual Exhaust / Dual Electric Fans / SCT Programer / Back up Camera / Back up lights / Jensen VM9312HD/DVD Radio-CD / 02 Lariat Captains chairs & Center Console / Over Head Console / New Carpet / New Headliner / Roll-N-Lock cover /
  #2 (permalink)
Old 01-12-2009, 04:01 AM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
If the padding is on tight, then you can apply spray adhesive and the new covering to it. Worst case is the padding eventually loosens and you have to do it again.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 01-12-2009, 04:23 AM
rsdjcarter's Avatar
rsdjcarter rsdjcarter is offline
rsdjcarter is starting off with a positive reputation.
Just make sure you use some quality adhesive. I used a cheaper brand once and it lasted about a week.
__________________
Rob
65 F100-Betsy With an Attitude
69 VW Fastback Drag Car-McNasty
71 VW Squareback-Zippy
94 Dakota Bledsoe-Red
  #4 (permalink)
Old 02-15-2009, 02:51 PM
RonC80's Avatar
RonC80 RonC80 is offline
RonC80 is starting off with a positive reputation.
I hope I never have to do it sounds like a big pain in the butt
  #5 (permalink)
Old 02-15-2009, 03:29 PM
ReAX's Avatar
2002 Ford F-250
It's not to bad, I watched a kid in my MECP class do his door panels in suede. Spray adhesive on the surface and stretch your material and smooth it out as you go. For the adhesive, they had some special stuff at school, but I've had good luck with 3m's Super 77 spray on adhesive.
__________________
  #6 (permalink)
Old 02-15-2009, 03:37 PM
Dan
Headliner
It was pretty easy once i figured it could be done without removing the old liner. The old liner except in one place was in good shape so glueing the new one to it was fine. I upgraded the 98 at the time and put an 01 overhead console in, by using the old lined under the new one it made that job easier since there was no gap to fill because of the extra thickness from the two liners.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
