Rod knock or lifter or what?
I have a 1974 F-250 with a 390 and supposedly 428 heads. I have a ticking sound which sounds like an exhaust leak from the number 4 and 6 cylinders. When I pull the spark plug wire off while it is running the sound goes away. That would be a rod knock, correct? The noise is only at idle and acceleration. If I hold the RPM at 1200 or higher the sound is not there. A rod knock is always present isn't it?
Compression checks out good. Oil pressure is 3/4 up the stock gauge. Sound doesn't change at all depending on engine temp. I put in a quart of Rislone but it did nothing. When I bought the truck the two problem cylinders also had the exhaust manifold gasket blown out around the exhaust ports, not sure if that is related.
I've seen on this forum about the wrist pin making noise. What causes that?
Where should I start?
[quote=1974f250;6997446]
When I bought the truck the two problem cylinders also had the exhaust manifold gasket blown out around the exhaust ports, not sure if that is related. quote]
Did you replace the gaskets? Pulling the plug wires would quiet a leak. A rod knock sounds like just that, a knock not a tick.
Brooce_AZ
Modular V10 (6.8l)
16
12-16-2013 10:45 PM
drwitzka
02-11-2005 12:37 AM
