Rear Wheel Hub Nut Socket - Ford Truck Enthusiasts Forums
Old 01-11-2009, 05:52 PM
BDalton's Avatar
BDalton BDalton is offline
BDalton is gaining momentum as a positive member of FTE.BDalton is gaining momentum as a positive member of FTE.
Okay, I am getting ready to replace the rear bearings and seals in my truck. I need the “special” socket to remove the hub nut. I have searched and searched and all I can find is one for the Ford 10.25 or one for the Dana 80 rear. I assume one of these will work on the 10.5, but I do not know which one? Does anyone have any ideas, or a part number on their socket I can get? Thanks,
Old 01-11-2009, 05:58 PM
rebelchevy02's Avatar
rebelchevy02 rebelchevy02 is offline
rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.
The one for the sterling axle, does both the 10.25, and 10.5 axles. When I got mine, I think I had just gotten it from autozone, or one of those types of stores. Have you looked in to the retorqueing specs for the rear axle?
Old 01-11-2009, 06:05 PM
BDalton's Avatar
Quote:
Yeah I saw the one Auto Zone had, but it only said 10.25, but if it will work on a 10.5 that is great. As far as torque goes I found:
60-65 ft lb, then back off 5 clicks for new wheel bearings
60-80 ft lb for the axle shaft bolts (with thread lock)
150 ft lb for the lug nuts
If these numbers are wrong or if anyone has better info please let me know. Thanks,
Old 01-11-2009, 06:06 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
this is all i could find on it
-Ford Rear hub socket (available at parts houses. Autozone didn't have one)
http://www.ford-trucks.com/forums/74...ake-shoes.html
Old 01-11-2009, 06:12 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
Make sure to torque the axle shafts and lugs with the weight of the truck sitting on them.
Old 01-11-2009, 06:15 PM
Yeap, those are the numbers. I had a hell of a time finding them, and ended up finding them at the ford garage, after looking though one of their huge manuals. IIRC for used bearins, you only back them off 3 clicks. But its been a while since I had mine apart. (this would be assuming your reinstalling the old bearings.) As far as the spindle socket, there is basically two. One that does the front axles, and chevy axles, and the ford sterling socket. But I havent done anything to the D80s or larger yet, so in MY world, theres two.
Old 01-11-2009, 06:17 PM
BDalton's Avatar
Thanks for the link, I got it book marked to help as a guide.
Old 01-11-2009, 06:18 PM
BDalton's Avatar
Quote:
Well that is new info. So just snug it up, then put it down on it's weight and apply the torque? Sounds simple enough, thanks.
Old 01-11-2009, 06:22 PM
BDalton's Avatar
That is exactly what I have found running around today and searching the web. I guess I'll go with the 10.25 Sterling socket. The old links that used to take you to motorcraft repair manuals don't work for me , they ask for a log in now. But I was able to scrounge those numbers from this board and googling stuff. Thanks,
Old 01-11-2009, 06:38 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
I torqued my rear axle nut according to info here on the forum recently. copied from a post:
Remove the caliper and wire it up out of the way so the line doesn't get damaged. Then remove the caliper anchor plate. Now the 8 axle bolts on the hub then slide the axle shaft out. Now you'll need the 4 prong socket.....remove the hub nut. Remove the outer rear wheel bearing and the rear hub and brake disc assembly. Then remove the bolts that hold the two together. (for a dually).
When you re-install the hub nut, push in on the socket so the ratcheting parts of the hub nut don't engage and tighten to 70 lb/ft and then back it off 90º. Now retorque it to 18 lb/ft to 20lb/ft max. ( quoted from AustinS)
Is this OK.. or should I redo the torque..?
Old 01-11-2009, 09:32 PM
Its been a while, since I did mine, but 90* backup, is probably pretty similar to the 5 clicks back off. HOWEVER, I cannot tell you they use the same system on th D80s, as the sterlings. I do not know the torque sequence for the D80s. I do think however that Austin is pretty good at getting accurate info, dang near word for word, I dont imagine he would have quoted that info, unless he though it to be true.
Old 03-02-2011, 09:20 AM
wnb007 wnb007 is offline
wnb007 is starting off with a positive reputation.
I know this thread is a little old but it comes up when someone googles this topic so im adding this for information purposes. I bought a Performance Tools PN-W83008 for 85-99 10.25" axles and it will NOT work on my 06 10.5" axle because it will not slide into the spindle. It might could be machined down in a lathe to fit but doesn't work as is from the parts store. Your in luck apparently if you have an older 10.25" axle Oreilly has them part number listed above for $17. The only one I can find that specifically says fits the 10.5" axle is OTC PN-6601 so Im going to order it.
Old 05-26-2011, 01:12 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
Just an update for the socket part numbers. Mile Marker makes the socket, # 15009-01 and it is for all F250, F350 and Excursions with the 10.5 rearend.
I found it at AutoZone.com priced at $20.99 with $6 shipping. The OTC part number is much more expensive at the $40+ range
I hope this helps others.
Old 11-04-2011, 01:50 PM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
MikeSDK is starting off with a positive reputation.
Does anyone have the part number for the Dana 80 hub?
I need to do this job ASAP, but can't find the socket-
Edit- Found one on Amazon. Should be OTC 7269
Old 11-05-2011, 04:05 PM
dhyayi dhyayi is offline
dhyayi is starting off with a positive reputation.
could you please tell us the link?
Changing the upper (secondary) fuel filter in a 6.0L bismic 6.0L Power Stroke Diesel 56 08-10-2015 10:35 AM
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 12:47 AM
installing new rear bearings. (01 DRW) PEI 1999 - 2003 7.3L Power Stroke Diesel 0 09-21-2012 04:01 PM
rear hub nut size? ak-angler 1999 to 2016 Super Duty 8 06-11-2010 07:26 PM
Front Hub Removal Knotwild 1994.5 - 1997 7.3L Power Stroke Diesel 14 09-19-2009 09:19 PM
Tags
1025, 105, 2002, 4x4, 80, axle, dana, dually, f350, ford, hub, nut, rear, remove, shaft, socket, sterling, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
