Rear Wheel Hub Nut Socket - Page 2 - Ford Truck Enthusiasts Forums
Old 11-05-2011, 05:35 PM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
MikeSDK is starting off with a positive reputation.
Pretty sure I got the last one currently available from the seller. If you put the Part no. in Google shopping, it will show you where to get them.
Old 11-18-2011, 08:17 AM
wrench26 wrench26 is offline
wrench26 is starting off with a positive reputation.
help
I'm trying to change my driver rear axle bearings! Bought the 4 prong tool for the nut but its either really tight or something is holding it! I don't see anything in the keyway! Anything that i am missing?
Old 11-18-2011, 10:38 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Remember that the left-hand (driver's) side is a left-handed thread in 10.5", corporate rear ends.
Turn the other way if that's what you've got.....
Pop
Old 11-18-2011, 11:17 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Don't you need to push on the nut with the socket while turning it?
Old 10-01-2012, 07:02 PM
sweetfarm sweetfarm is offline
sweetfarm is starting off with a positive reputation.
lock nut
Quote:
Yes you need to apply pressure while turning it. The socket that I bought was hub pilot centered. After you remove the lock nut and bearing you reinstall the socket into the hub center. The socket has a depression in the middle to hold the puller while you remove the hub. I have seen lots of conflicting ideas on torquing the bearings on this forum. Torquing them to 65 ft lbs and then backing them off 1/8 turn seems to work. But I am no expert, just my experience.
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 01:47 AM
Auto Hub Spindle Nut Socket Macs1964F100 1987 - 1996 F150 & Larger F-Series Trucks 2 07-15-2014 08:32 AM
installing new rear bearings. (01 DRW) PEI 1999 - 2003 7.3L Power Stroke Diesel 0 09-21-2012 05:01 PM
rear hub nut size? ak-angler 1999 to 2016 Super Duty 8 06-11-2010 08:26 PM
2002 F250 rear rotors. Pull the axel shaft? pcctim 1999 - 2003 7.3L Power Stroke Diesel 8 04-14-2009 12:45 PM
Tags
1025, 105, 2002, 4x4, 80, axle, dana, dually, f350, ford, hub, nut, rear, remove, shaft, socket, sterling, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
