xlt rim
01-11-2009, 02:55 PM
on
xlt rim
i was wondering if anyone knew if a 305 size tire will fit on a 2004 xlt rim? im am ready to put a 2.5" front lift on but i like my stock rims. what tire size can i go with? thanx
01-11-2009, 03:46 PM
on
with a leveling kit you can fit 35s real easy on the factory rims. That equates to roughly 315s
01-12-2009, 12:03 AM
4x4 yes
4x2 no
305 will be roughly a 33" tire...and the 4x2 will have issues fitting it without rubbing.
the rims are 7.5" wide...the tires will fit, but they won't be as wide as normal since the rim is skinny.
edit: didn't see the 2.5" part...never mind, a 33" will fit a 4x2 with that installed
01-12-2009, 07:46 AM
on
yeah its a 4x4. i always looked at it this way. whats the point of getting a truck if it aint 4x4. but a 315 will fit with no problem?
01-12-2009, 10:05 AM
yeah, a 315 will fit without any problem...maybe a tiny bit of rubbing at full lock
any wider though (325 width...12.5" wide) and your tire tread will be about 1/4" from rubbing the upper control arm...the 325 will work as well though
01-12-2009, 07:10 PM
on
do you know where i can get a bfg a/t 315 at? cheapest i can find is $239. on line.
01-12-2009, 07:23 PM
on
01-12-2009, 08:00 PM
on
Quote:
Originally Posted by
rplatt56
check out the Nitto's
I like the Nitto's. When my tires fall apart, I'm going with those after lifting the truck.
01-12-2009, 09:19 PM
4getfulbj
that is an awesome price...but how much is shipping?
I've found that Sams Club/Costco are actually pretty good places to shop for tires...but Discount Tire and Tirerack.com are probably the cheapest
I'm getting quoted $349 for a 35/12.5/18 in the BFG A/T, and $360 for the same tire in the M/T
01-12-2009, 09:27 PM
on
what about hankook m/t those look nice and they rate real good.
01-12-2009, 09:47 PM
like the way they look in pictures, but I've never seen 'em in person
if the price is right, go for it.
txjfrosty
1999 to 2016 Super Duty
03-16-2014 01:32 PM
Baker444
06-07-2012 03:39 PM
Tangmus
10-12-2009 08:10 PM
Stangfire
1997 - 2003 F150
05-03-2004 11:11 AM
JAAMina
1997 - 2003 F150
10-01-2003 03:03 PM
2000 ,
2004 ,
2007 ,
2008 ,
2009 ,
f150 ,
fit ,
ford ,
rim ,
rims ,
size ,
stock ,
tire ,
xlt
