'99 7.3 runs rough after warm-up - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-11-2009, 02:19 PM
badsport badsport is offline
badsport is starting off with a positive reputation.
I have a 99 F350, 7.3 that after warm up the service engine light comes on and truck runs very rough. No codes will come up. It runs fine until warm up.
The truck has 245000 miles on it with no real problems. The cam position sensor has been changed under recall, and of course the high pressure pump hose o-rings.
thanks in advance,
John
Old 01-11-2009, 06:02 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE. What are you using to pull the codes? The free scans at the parts stores won't read the engine codes in these trucks. Can you describe the rough running a little better? Does it feel like a miss, or like the engine is not firing on all cylinders?
If the CEL (check engine light) comes on, there is a code there. You just need the right kind of code reader to see it. This kind of sounds like a loose UVCH (under valve cover harness) issue. When things heat up, the connection gets worse. If you have an ohm meter handy, read through this thread that has pictures and the test procedure so you understand what you're looking for. http://www.ford-trucks.com/forums/80...ck-shakes.html
Come back and let us know what the test shows.
Old 01-11-2009, 10:16 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
thanks in advance,
John
I agree with Chris.. It sounds like the famous under the valve cover 9 pin plastic piece of junk connector is loose... You can remove the cover/s and made a shim out of a 25 cent coin to keep it tight... You can reuse the covers gaskets, so the total cost for both sides is 50 cents (plus your labor)... Yes, if you have CEL light than you have a fault code recorded.. probably a P1316.. Also, check the wiring under the covers for rubbing.. Another area is on top of the driver's side cover. The main wire harness rubs on the top of the cover.. Let us know what you find..
oil in the fuel filter bowl skippy73 1999 - 2003 7.3L Power Stroke Diesel 9 03-30-2015 04:58 PM
Rough idle after truck warms up 99 300k+ stroker Performance & General Engine Building 3 05-08-2014 05:18 PM
7.3 starting issues.. Zeropowerstroke99 1999 to 2016 Super Duty 5 04-12-2014 01:49 PM
Warm up a 7.3 ? Polkster 1999 - 2003 7.3L Power Stroke Diesel 4 03-31-2014 10:35 AM
99 7.3 starts cold runs rough dies when warm mclaughlin16846 1999 - 2003 7.3L Power Stroke Diesel 7 02-18-2014 03:46 PM
Tags
1999, 73, 73l, bad, codes, diesel, engine, light, rough, running, runs, service, warm, warmed, warms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
