Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-11-2009, 12:38 PM
tvl tvl is offline
tvl is starting off with a positive reputation.
Transmission Explanation Needed!
I have a few simple questions for the Transmission guru:
1- What is the difference in the 6 speed ZF 6HP26 and the 6 speed 6R75?
2- Are either of the above mentioned models considered to be a TorqShift transmission?
3- On a 2008 Expedition equipped with the 6R75 transmission, what is the recommended service interval for changing fluid under normal driving conditions (we do NOT pull a trailer with this vehicle)
Thanks!
  #2 (permalink)
Old 01-13-2009, 06:09 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
3. My dealer told me I didn't need it at 30,000 miles, even in towing service. Probably 60K for towing and twice that for normal driving. I pull my camper a dozen weekends in the summer.
-- Chuck
  #3 (permalink)
Old 01-19-2009, 11:03 PM
rich93cw rich93cw is offline
rich93cw is starting off with a positive reputation.
Thanks!
I believe that the ZF is used on the Navigator. It does not have a low 4x4 range. The 6R75 is used on the Expy. It has a high and low 4x4 ranges.
I believe that the 6R75 does not have a fluid change interval, nor does it have a fluid level dip stick. It also uses a very special auto trans fluid available only from Ford. Best check you owner's manual. It should all be told in it.
  #4 (permalink)
Old 01-20-2009, 12:21 PM
Z06PSI's Avatar
Z06PSI Z06PSI is offline
Z06PSI is starting off with a positive reputation.
I have a 05 with the ZF and it has low 4x4.
__________________
Andrew, Christine, and Aidan Baker
2005 Navigator Ultimate
2002 Mil Yel ZO6 - 383 stroker 2.8L Kenne Bell and methanol.
  #5 (permalink)
Old 01-20-2009, 01:13 PM
Looks like I need to reread my owner's and shop manuals!!!
  #6 (permalink)
Old 01-23-2009, 09:12 PM
chevy24d chevy24d is offline
chevy24d is starting off with a positive reputation.
I am not sure which exact tranny I have but I just found out at the 30,000 mile service that there is no dipstick! What is that all about? I had the fluid and filter changed for well over $200 but this is on my maintenance schedule. (Chuck - you may want to double check your dealer) Also, there is some special tool needed to flush the trans.
(2007 expedition xlt)
  #7 (permalink)
Old 01-27-2009, 09:09 AM
blackout150's Avatar
blackout150 blackout150 is offline
1998 Ford F-150
blackout150 is starting off with a positive reputation.
I read in my owners manual that the 07 & 08 trannys have no dipstick and you have to take it to the dealer to check the fluid level. Isn't that fantastic, another way to get you to pay. I want to install a heavy duty cooler, but I know it will require more fluid so either I get them to do it or I dont add the cooler? nice.
__________________
4.2 - 5spd. thats all.
  #8 (permalink)
Old 01-27-2009, 02:09 PM
carbonmetallic carbonmetallic is offline
carbonmetallic is starting off with a positive reputation.
Quote:
ford claims the transmission fluid doesnt need to be changed till 100K and that is why there is not dipstick. This is a joke, if this were really the case, they ought to remove the dipstick for the F250, F350 and on up. Ford is just trying keep there service departments alive and seem to be cutting corners to save a few bucks here and there.
__________________
07 Ford Expedition Eddie Bauer
K&N drop in filter
Truxxx Leveling kit
285/70/17 Hankook Dynapro ATM RF10
SCT X3 Custom Tuned by Mike at 5 Star Tuning
  #9 (permalink)
Old 01-27-2009, 10:29 PM
Quote:
-- Chuck
FYI This is from my maintenance manual for 30,000 miles. I will admit, I do not know if my tranny is called a Torqshift transmission? but I assume I needed to change the oil at the dealer as I just did. ❑ Change engine oil and replace oil filter.❑ Inspect tires for wear and rotate.❑ Inspect brake pads/shoes/rotors/drums, brakelines & hoses, and parking brake system.❑ Inspect wheel ends for endplay and noise.❑ Inspect engine cooling system and hoses.❑ Inspect exhaust system and heat shields.❑ Inspect steering linkage, ball joints, suspensionand, if equipped, halfshafts, driveshaft andU-joints.❑ Replace engine air filter.❑ Replace fuel filter (see page 47).❑ Replace cabin air filter, if equipped.❑ Change automatic transmission fluid on vehiclesequipped with the Torqshift transmission. Replacethe remote filter element on the vehiclesequipped with the . Inspectautomatic transmission/transaxle fluid levelon all other vehicles, if equipped with dipstick.Consult your dealer for your particularrequirements.❑ Replace climate-controlled seat filters if equipped(Navigator and Expedition).❑ Lubricate ball joints and steering linkage ifequipped with zerk fittings.❑ Inspect and lubricate 4X4 front axle shaft U-joints(F250/350/450/550).❑ Multi-point inspection (recommended)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
