1992 explorer relay
1992 explorer relay
Anyone know what the 2 relays under the fuse panel that is located in the engine compartment go too? The front relay is ticking and I don't know what it is or if it is going to fail soon.
Thanks for any help, Justin
This site so rocks....Thanks agian to the guys for the heater core instuctions for the 97 F-150......U dudes saved me sooooo much time.
One will be the EEC relay (that powers the engine management system), the other will be the fuel pump relay. Factory relays are usually black for the EEc relay, and green for the fuel pump relay, but there's no telling what you'll get if they've been replaced. If you look at a wiring diagram to see what color wires go to which relay should allow you to identify which relay is which (the ones in Chiltons are usually adequate for this, and can be obtained for free in the vehicle repair guides at autozone's website if you don't have the print manual).
rockpile
07-26-2016 12:28 AM
TheBlueMule
03-21-2016 08:41 PM
