1992 explorer relay - Ford Truck Enthusiasts Forums
1992 explorer relay
Old 01-11-2009, 12:43 PM
justin_pistol justin_pistol is offline
justin_pistol is starting off with a positive reputation.
1992 explorer relay
Anyone know what the 2 relays under the fuse panel that is located in the engine compartment go too? The front relay is ticking and I don't know what it is or if it is going to fail soon.
Thanks for any help, Justin
This site so rocks....Thanks agian to the guys for the heater core instuctions for the 97 F-150......U dudes saved me sooooo much time.
Old 01-11-2009, 11:22 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
One will be the EEC relay (that powers the engine management system), the other will be the fuel pump relay. Factory relays are usually black for the EEc relay, and green for the fuel pump relay, but there's no telling what you'll get if they've been replaced. If you look at a wiring diagram to see what color wires go to which relay should allow you to identify which relay is which (the ones in Chiltons are usually adequate for this, and can be obtained for free in the vehicle repair guides at autozone's website if you don't have the print manual).
Old 01-12-2009, 09:52 AM
Thanks for the info, The relay is still ticking and the truck is still running fine.
I guess I should replace it anyways??????
Thanks agian, Justin
Old 01-12-2009, 10:55 AM
Maybe. I expect most people would say to go ahead and replace -- they are inexpensive and easy to change, so you won't be out much if it doesn't fix it.
I might switch the two relays and see if the "ticking" follows the relay or stays with the socket.
Old 01-12-2009, 03:43 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
As Mrshorty said, you should switch the 2 and see if the problem moves. If it does, then I would replace the one that ticks. If either of these relays goes out, you will be in a no start situation.
Headlight relays 036.0stroke 1967 - 1972 F-100 & Larger F-Series Trucks 10 05-06-2016 03:26 AM
What size fitting for supply line on injection pump TheBlueMule Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-21-2016 09:41 PM
Need 2011+ F250 Tow Mirror Wiring Diagram outofcontrolreb 1999 to 2016 Super Duty 0 12-14-2014 08:51 PM
Remove bendix drive from a Y-block starter Justin3055 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 06-14-2010 08:42 PM
what does the horn relay look like? Justin460 1987 - 1996 F150 & Larger F-Series Trucks 4 09-06-2007 07:38 AM
Tags
1992, 1999, 2002, 91, 92, 94, ac, eec, explorer, ford, location, ranger, relay, relays, removal, sw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
