Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-11-2009, 01:39 AM
65Tuxedo 65Tuxedo is offline
65Tuxedo is starting off with a positive reputation.
power steering conversions question
Got a p/s unit from a 75 to put on my 72 V8. Think I have all brackets and bolts etc. Could someone post a pic of how the pump is attached to the engine?
I have done several searches but have been unable to find any diagrams or pics.
Thanks,
  #2 (permalink)
Old 01-13-2009, 10:21 PM
72bronc's Avatar
72bronc 72bronc is offline
72bronc is starting off with a positive reputation.
Sorry no, when I did my power conversion i used a pump from a latemodel explorer 302 and converted to a serp. belt. those early pumps are too unreliable. I f you post a pic of the brackets u have I'm sur i could tell you where / how they go
  #3 (permalink)
Old 01-13-2009, 11:02 PM
I think I have figured out where the pieces go but I do have another question. The bracket that attaches to the head has a shaft with threads on each end. I am afraid of damaging the threads by trying to turn the shaft inside of the bracket. It seems locked tight. How do you attach the thing to the head?
Thanks
  #4 (permalink)
Old 01-14-2009, 01:41 AM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
Quote:
Thanks
There are 2 ways to do this, depending on how much you sticking out of the end of the pump bracket you have to work with.
I would recommend cleaning the threaded hole in the head with a tap so that it will go together easier.
If you have plenty of threads, put 2 nuts on the end of the threaded rod and jam them together. Slide it into the bracket and start into the head. Tighten until it bottoms out.
I have also taken the radiator loose, installed the threaded rod. And then installed the bracket onto it. In those cases, I didn't have enough threads to do the nut trick.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #5 (permalink)
Old 01-20-2009, 10:22 PM
Got the p/s installed. What a difference. Glad I did this early on. Lot of trial and error, learned a lot about adjusting the steering column.
Thanks for the help.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
