'95 F250 headlight switch problem
I fixed it yesterday. Took the plastic column wraparound off (3 screws), ignition lock ring, under the two silver trim bezels there are two screws that need to come off, and the dimmer needs to slide off. Then the black gauge dash pulls right out. Unplug the fuel selector switch and its easy access to the light switch. You push down on the spring under the switch to slide the switch rod off to put in new one. Then reverse to put back together. Twenty minute job.
patho44
1999 to 2016 Super Duty
03-14-2014 10:31 AM
RangerDude17
01-26-2014 03:30 PM
