Quote:
Originally Posted by RCrawler
U14- Bronco half cab
N- 289 V8
L- Michigan truck plant
B42--- - the build sequence in Aug 67 ends in A171999, and picks up in Nov as C42000. I couldn't find any info on the B prefix in the sequence number. FTE has a new VIN decoder and it came up with Oct 67 as a build date. So that sounds pretty close to me. Jason
The FTE VIN decoders aren't worth a damn, are rife with omissions and errors.
A
Bronco assembled in October 1967 will be a 1968 model.
New vehicle introduction (usually) begins in September of the previous year, so production usually starts in late July or August.
1967
Bronco start/end serial numbers: August 1966: A00,001 // August 1967: B82,000
U14NLB42842
B42842 = Assembled June 1967.
1966/72
Bronco Serial Number ranges:
1966: 732,001 thru 914,000
1967: A00,001 thru B82,000
1968: C00,001 thru D82,000
1969: D82,001 thru G30,000
1970: G30,001 thru J70,000
1971: J70,001 thru M30,000
1972: M40,001 thru Q00,000.
Source:
1965/72 Ford Passenger Car
Parts Catalog /
Bronco Warranty Plate/Certification Label codes / Pages 40 thru 44.
You can buy a CD of this catalog from hipoparts.com for less than $25.00.
hipo also has the 1973/79 Ford Passenger Car
Parts Catalog and the 1980/89 Ford Light Truck
Parts Catalog on CD's.
Bronco's are listed in the car
parts catalogs from 1966 thru 1979. In the light truck
parts catalogs from 1980 thru 1996.
From the
parts catalogs, I can decode
all the info found on
Bronco Warranty Plates and/or Certification Labels from 1966 thru 1996.
