Here's a drivetrain diagram that may be helpful. - Ford Truck Enthusiasts Forums
Old 01-09-2009, 11:50 PM
mando jake's Avatar
mando jake mando jake is offline
mando jake is starting off with a positive reputation.
Lightbulb Here's a drivetrain diagram that may be helpful.
I made this to explain to someone the different drivetrain configurations in our trucks, and I thought maybe it would be useful to some of you guys.
Old 01-10-2009, 02:03 PM
460's Avatar
460 460 is offline
460 is gaining momentum as a positive member of FTE.
Nice diagram, thanks for posting!
Old 01-10-2009, 03:23 PM
F250army45d F250army45d is offline
F250army45d is starting off with a positive reputation.
Jake thas pretty nice!! Hey not to jump off the pretty pictures but some one said you might have an NP542 on the market? PM me if you do.
Old 01-10-2009, 03:39 PM
mando jake's Avatar
I'm keeping the one I have, but I have seen a few in the junkyards. One even had a PTO winch and a wrecker body. Lots of F600's and F500's will have them.
Old 01-10-2009, 05:28 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
nice diagram. probably better than what I could do.....
Old 01-10-2009, 05:33 PM
dakonthemountain dakonthemountain is offline
dakonthemountain is starting off with a positive reputation.
Thanks for the education! Not having a 4x4 truck (though I do have a 4 x 4 GMC Jimmy), I always wondered what the difference was between a "divorced" and "standard" set up. After seeing your diagram it makes perfect sense! Points given..
Dak
Old 01-10-2009, 05:42 PM
Dr. Dirt's Avatar
question on the divorced transfer case:
since the divorced case sits farther back does that mean the shifter on the inside of the cab sits farther back?
Old 01-10-2009, 05:47 PM
mando jake's Avatar
No. It does not. The shifter moves linkage that runs back to the case.
Old 01-10-2009, 06:14 PM
4x4 Bart 4x4 Bart is offline
4x4 Bart is gaining momentum as a positive member of FTE.
Good simple diagram! This will help some folks get up to speed.
Old 01-10-2009, 09:58 PM
78workhorse's Avatar
78workhorse 78workhorse is offline
78workhorse is starting off with a positive reputation.
Thanks for the education. I too was curious about the devorced trans. Out of the 4 trucks Ive had Im happy to say Ive never had one. Me and the Mrs. are still together too. Points wil be given.
Old 01-11-2009, 03:06 PM
Dr. Dirt's Avatar
alright, thanks mando jake.
Old 11-29-2010, 11:44 PM
mando jake's Avatar
Updating an old thread. I've had a lot of people asking what a double transfer case setup is, and what it even does. I hope this diagram helps.
It gives an additional selectable low range, by using a hi / lo range section from a transfer case in front of a transfer case.
Old 11-30-2010, 07:14 AM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
I am waiting for someone to say that there front drive shaft comes straight out there xfer case, not at a angle like your diagram, lol.
Nice job BTW, and FYI "standard" is sometimes referred to as "married" just to help out.
Old 11-30-2010, 11:01 AM
Joseph69's Avatar
Joseph69 Joseph69 is offline
Joseph69 is starting off with a positive reputation.
Diagram is pretty close, the NP205 has that angle to it. But the BW1356 is a little straighter
Old 01-28-2011, 01:50 PM
460's Avatar
460 460 is offline
My transfer case isn't green either.
Spare tire gate mount carrier from Bronco mando jake Ford Truck Parts for Sale 1 06-26-2014 09:01 AM
Trac lok pros/ cons? mando jake Offroad & 4x4 4 09-02-2009 01:12 AM
What about a shaft drive pto winch? mando jake Offroad & 4x4 12 08-11-2009 01:15 AM
What is this bracket on my 91 D60? mando jake Offroad & 4x4 10 07-02-2009 06:00 PM
Will a Dana 60 carrier fit into the Dana 50 housing? mando jake 1999 to 2016 Super Duty 13 03-24-2008 09:13 AM
Tags
2006, 76, diagram, diagrams, drive, driveline, drivetrain, explorer, f100, f150, f250, ford, layout, schematics, train, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
