Synthetic Oil
Synthetic Oil
After the cold temps that we have had here in Fairbanks recently, I am considering changing over to synthetic oil because I have been told that it is easier on your engine in cold weather. Is this so? Also I am concerned about the synthetic oil eating any seals or doing anything adverse to my engines' internal parts. Is there anything about synthetic oil that I should look out for?
Actually, in a 1996 test, Consumer Reports tracked 75 NYC cabs and found no real difference in performance between syn and dino. I mention that only because they made a caveat that "Big-city cabs don't see many cold start-ups or long periods of high speed driving in extreme heat." This seems to answer your concerns.
Bob
Bob
I always pick up Mobil-1 turbo diesel truck oil at Walmart then I drive over to Seekins and let them change it for me. with the cost of the filter it cost me let than $25 and I drink there coffee.
While we're on the subject of syntenic oil (5W-40)...and the fact that I'm too lazy to dig through countless back threads to find the answer. Can I run that light of an oil year round? I can clearly see the advantages during the winter...but I'm worried about the summer. It gets over 90F for weeks at a time with 100F for a week or two where I live...so summer heat would be an issue.
Some will say (me that is) that synthetic fluids flow better upon start-ups and better lubrication year-round is better. As well, the high heat protection of a synthetic for your turbo bearings is a GOOD thing.
Just use synthetic oil for the benefits of using and not because you want extended oil drain intervals. Use a Motorcraft or Racor (OEM) oil filter and change on schedule and your motor will amaze you.
I have 139,000 miles with 100% of the parts my motor was built with... but I think that my dieselsite.com coolant filter has a lot to do with that along with my conservative oil change program of synthetic oil and Motorcraft/Racor oil filters.
