Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Tennessee Chapter
Sign in using an external account
Register Forgot Password?
Tennessee Chapter Join Chapter Leader:
  #18976
Old 12-17-2014, 06:25 PM
fire240's Avatar
fire240 fire240 is offline
DE Chapter LDR
fire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputation
I know what you mean.
__________________
Shaun from MD
2009 F-150 Super Cab XL 4X4 4.6L 2Valve V8 My build thread.
Big Bser number XO Slackmaster#5
RIP Stevebricks. You will be missed.
Join the DE Chapter here
  #18977
Old Yesterday, 05:53 AM
SC_Hoaty's Avatar
SC_Hoaty SC_Hoaty is offline
SC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputation
Nice truck for the money, Dylan, even if it takes a few more $ to get it running good. I sold a 93 F150 Ext. Cab V8 about 2 years ago for ~4K, so you did good.
Wonder how the spark advance is controlled? Manifold vacuum, maybe? See if you didn't damage one of those little plastic vacuum hoses when you BBQ'd the filter and stuff.
If there are no vacuum lines, it may have a direct reading Manifold Air Pressure (MAP) sensor. Check for damage its wires.
You might be able to get some readings from the computer at a local parts shop instead of just throwing parts at it. If the parts shop can't help, maybe a decent mechanic can read the computer and let you do the work.
Good luck!
We can always fling it into the ocean for ya!
__________________
2009 F250 SC LB 5.4
2008 F250 RC LB 5.4
2005 F150 FX4 5.4
  #18978
Old Yesterday, 12:54 PM
Chad149's Avatar
Chad149 Chad149 is online now
Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.Chad149 has a spectacular reputation.
Unplug the mass airflow sensor (MAF) and see if it changes for the better. Ford's back up strategies are pretty good. Ain't gonna be perfect, but if it runs much better that's a good start, and the MAF sensors are right by the air filter. I believe the logic in the ecu doesn't need that input for much at wide open, which may explain why flooring it helps.
__________________
2012 XLT F-350 6.7 Powerstroke 172" WB Fab Four rear bumper w/Rigid lighting, Cooper ST MAXX 295-70-18
A man’s rights rest in three boxes: the ballot box, the jury box, and the cartridge box.”
  #18979
Old Yesterday, 03:23 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is online now
WAFTE Chapter LDR
GruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant futureGruesomeJeans has a brilliant future
pages/Bronco-Nation/333812929968547 GruesomeJeans
Wouldn't the MAF also control the idle too? It idles really well. Both in drive and in park, then sometimes when I drop in drive it feels like it wants to die for a split second but then goes back to normal. But I can try that.
__________________
1978 Ford Bronco Ranger XLT *The Green Machine* 351Mutant§35x12.5R15§3" Body lift§
1987 Ford Mustang GT§Drag Radials§5 speed§FAST!§PGM
Leading The Washington Chapter With An Iron Fist! - Dylan
Visit Washington Chapter HERE!
Washington Member Map
  #18980
Old Yesterday, 03:46 PM
fire240's Avatar
DE Chapter LDR
Morning Everyone.
__________________
Shaun from MD
  #18981
Old Yesterday, 05:35 PM
Chad149's Avatar
Quote:
not really. I believe that truck also has an idle air control motor that opens and closes a small port to bypass the throttle plate. That would be your major player in that arena.
__________________
  #18982
Old Today, 02:54 AM
WAFTE Chapter LDR
I've delt with IAC before, it makes me want to convert to carb... it's a pain dealing with electronics, but I plan to get a cheap scanner and try that.
  #18983
Old Today, 07:54 AM
SDElwood's Avatar
SDElwood SDElwood is offline
Official BeerMaster #1
SDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputationSDElwood has a superb reputation
https://www.facebook.com/mike.blackport
What's that got to do with Tennessee Whiskey?
__________________
Mike -
2000 4x4 CC LB F-350 7.3L SuperChips Flashpaq, 4" turbo back exhaust, 6637.
Quote:
Originally Posted by Toyman View Post
Dude you get thirsty at mid swallow of your beer, don't hide it.......
Warning: Drinking may cause memory loss. Or worse. Memory loss.
Found Often Rescuing Dumbasses.
  #18984
Old Today, 07:59 AM
Toyman's Avatar
Toyman Toyman is online now
Beer reduction specialist
Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.Toyman has a spectacular reputation.
toyman
I think I drank most of it last night......
__________________
Hi my name is Rich, I am a cornerholic..........
2005 F250 Superduty crew cab, 6.0L, 4" turbo back, XPD egr delete,AFE stage 2, HPOP, headgaskets, studs, SCT tuner, scan gauge II, blue spring, zoo-dad mod, FICM.
1979 Bronco, 520 stroker, full roller, trick flow heads, reverse manual c-6, maddog fenderwell headers, 3 row aluminum radiator, derale trans cooler.
  #18985
Old Today, 08:13 AM
SDElwood's Avatar
Hey Rich, think we can fix that F-150 with the trebuchet?
__________________
Mike -
  #18986
Old Today, 08:54 AM
Toyman's Avatar
toyman
I'm already on it.
__________________
  #18987
Old Today, 10:35 AM
WAFTE Chapter LDR
Quote:
Well, you know mike, if my f150 gets fixed, I can easily "procure" quite a few barrels of whiskey, and follow the bus to the next stop! So it's related... in a very roundabout way.
Old Today, 10:35 AM
Similar Threads
Fuel tank problems Hughesjr84 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 07-08-2014 07:16 AM
Blue Hen Mall skirk55 Delaware Chapter 7 02-26-2010 11:47 PM
2007 March Meet--and --Greet savage2211 Delaware Chapter 48 03-11-2007 03:05 PM
THREE BUCKS A GALLON FOR KERO? Why???? Greywolf Tennessee Chapter 0 02-10-2006 09:34 PM
post joke Smaug New Member Introductions 3 06-16-2005 12:01 PM
Tags
638, beer run, bronco, clubs, ford, gang, george's credit card, magic carpet, tractor, traveling, truck, trucks, wagon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
