1995 F250 Diesel Fuel System problems
The fuel filter light comes on the rear tank and starts stalling. I have to switch to the front tank and then when at a light or turning it stalls out when I am on the front tank.. I have put in new fuel pump, transfer valve between the tanks and a few other things. My friend says the hoses to the tanks are not right and I need a schematic for a F250 1995 Diesel 7.3L
I have also cleaned out both tanks and removed the "socks". Also both tanks do not register fuel levels now. I have owned this truck since July. Problem started when have 2 months of running bio fuel the guy switched (without telling me first) that he changed his mixture of Oil 80% and diesel 20% to all oil!
It can do more than that. Cold oil in a cold engine wont atomize and burn properly and will gum up the rings,once that happens you start scoring the cylinder walls and letting vegoil into the crankcase. Vegoil is not a good lube and you can do some damage to the bearings.
Nah, It's not bad as long as you do it the right way. It has to be clean, dewatered , the engine has to be up to operating temperature and the oil at least 160* before you switch over to it.
At shut down you have to switch back to #2 far enough in advance so that all the veggie has time to be purged out of the system so that the next time you start you're running on #2 and not leftover oil in the system.
OBS PSD's are actually one of the easiest trucks to convert to WVO because we already have dual tanks and internal fuel rails that help heat the oil.
on
dfletcher
05-23-2014 02:09 PM
tpolley
10-15-2011 08:46 PM
