1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
fuel problems i think
Old 02-11-2014, 03:20 AM
dann167's Avatar
dann167
dann167 is offline
Got a 99 F450 7.3 with 190k miles, started acting sluggish. When cold, it wouldn't stay running, almost as if out of fuel. Would stall out when you pressed and released the accelerator but would idle fine. Now, it won't even stay running. Still acts like it's out of fuel. Changed the air filter, fuel filter, and added injector cleaner and conditioner. What else could it be? after warming up when shifting gears and letting off throttle it stalls and when restarted lets off blueish white smoke.
Old 02-11-2014, 05:36 AM
redford's Avatar
redford
redford is online now
Received 1,559 Likes on 908 Posts
Welcome to FTE, dann167.
Fuel pump or Idle Air Control (IAC) valve are 2 possibilities that come to mind.
Old 03-02-2014, 06:59 AM
dann167's Avatar
dann167
dann167 is offline
1999 f450 7.3
i changed the fuel pump and filter cleaned the tank out got it to run but once the rpm hit about 2200 the truck would start acting up and i would have to let off the throttle
dougcepress
Modular V10 (6.8l)
05-10-2016 04:12 PM
IHdieselfan
11-20-2011 08:41 PM
paddler
04-06-2009 03:04 PM
steve450r
18
01-24-2007 11:13 PM
denangme
09-23-2005 09:46 AM
Quick Reply: fuel problems i think
