Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-08-2009, 09:42 PM
Baumbach Baumbach is offline
Baumbach is starting off with a positive reputation.
Whistle Noise When Changing Temperature
The dealer replaced the A/C evaporator coil to fix my complaint about the air ducts making a whistling noise, the fins that the air passes through have a different design on the new evaporator coil, this did stop the air noise. The replacement kit included a new blower housing and a condensate pan with a longer drain, the installer told me it was about a 1/4" longer, I hope this also fixed by A/C condensate leak, I will not know until next summer. The replacement required the dash to be pulled apart, heater core to be removed, and the A/C recharged with refrigerant (big job). There is a TSB 08-9-8 MAY 08 A/C - Whistle Noise When Changing Temperature. Some 2007-2008 Expedition and Navigator vehicles built before 12/4/2007 may exhibit a whistle noise from the heater/air conditioning while changing temperature setting. If you are pre 12-04-07 and still under your 3 year 36k warranty, you might want to look into this..
  #2 (permalink)
Old 01-09-2009, 10:29 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is starting off with a positive reputation.
Can you explain how the whistle sounds and when it is created? How much of a temp. change creates this condition?
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
  #3 (permalink)
Old 01-09-2009, 04:23 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
Mine does it. I just have not taken it in yet.
  #4 (permalink)
Old 01-09-2009, 11:48 PM
Quote:
Does it in heat only, this will make it the worse….. Set air to blow out of floor and vents and the same time, fan ½ to ¾ speed, now adjust the temperature, starting with a low setting and then start to increase slowly one or two degrees at a time, and at a given point, when it calls for more hot air, the air ducts will start to whistle..
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
