replacing positve battery cables on 2004 F-350 6.0 turbo-diesel superduty
Curiously, my positive battery cable that runs from the driver side to passenger side has corroded so much that the cable broke at the base of the terminal mount on the postive post of the passenger side battery. I have only 52,000 miles on the engine. So, it's puzzling why it corroded so quickly. It is partly my fault for not regularly cleaning the terminals----my bad. I haven't been driving the truck that much lately.
I bought the OEM Ford replacement battery cable assy. However, the exchange process looks like a bitch. Can you guys give me some tips or provide a link on the replacement procedure? I never though replacing battery cables could get so involved.
I just changed the cable on a friend's 1 year old Ford Fusion. The whole end of the cable was completely green and fell apart. Upon closer inspection there was a very small crack on the battery case at the + post. It was under the terminal so you could not see it when it was hooked up. Had to get the battery replaced or it would have just corroded again. Sorry I can't offer any shortcuts but maybe the cause of the problem. Hope it helps.
I replaced the same cable you are talking about on my 04, Its about a 1hr or more job.. Its kind of tricky because it runs over the motor mount cross member and along the edge of the oil pan to the starter. If I remember, I think one of the brackets that secures the cable is mounted to some studs on the oil pan where it bolts the engine block, these are a PAIN!! I did mine laying on the ground a lift would help with the replacment. Good Luck!!
Did you have to remove the battery....remove any tubing to ease the install? It's a tight fit in there.
Thanks! I'm just waiting on warmer outside temps to work on it. It's 20 degrees here. I hate winter.
Oil pan? Did you get oil spillage?
You're right....changing the cable assy is an abortion!!! The engineering is too "busy". It could be much simpler. They want to make it 'knuckle-busting' complicated so folks have to bring their vehicles to the dealer. bah!
I'm about 80% finished with the job and will finish tonight.
Any pointers on R&R-ing the thing? It looks...awful.
Thanks.
