Supercharging my V-10
Ok so I want to throw a supercharger on my 2002 V-10 Excursion, Yet every kit I have seen stops at 2001. I even called Paxton and was told he didn't know of a difference but the demand wasn't there to test after the 2001 model. My question is there a difference in the V-10 computer, fuel system or... that would prevent this system fom working on my truck Paxton Automotive - Supercharging Systems For The 1998-2002 V-10 Ford Truck & SUV . The link says 98-02 but the site says diff. I also checked the supercharger, turbo section but with no help
Vortech makes a kit also. Vortech Engineering: Viewing product: 1999-2003 Ford F-250, F-350, Super Duty, Excursion Supercharging Systems
Saw this under the asterick so maybe there is an issue.
Please Note:
*Supercharged horsepower and torque data shown is a calculated estimate based on percentage increases from actual rear wheel hp/tq measurements.
*Supercharging systems are not available for 2002 Ford 6.8L F-250, F-350, Super Duty and Excursion.
IMO a screw S/C would be better but nobody makes them anymore. I would not worry about the computer compatibilty because the truck should be tuned on the dyno anyway for the most in safety and power even then the computers are pretty much identical. Fuel system should be the same as well as the mechanical parts. There are bunch of other guys on here that know more about this topic than I do as they have force fed V10s.
Please Note:
Are there any companies that would be able to tune the computer for the paxton setup or is there even a difference between the two computers (2001-2002)?The guy at Paxton said he wasn't even sure there was a difference they just never looked into the 2002. Or if someone could direct me to a member or site that would be able to help me out. I would really love to have this setup on my truck
Have you talked to our new sponsor 5 star....He seems cool and to know his stuff.
To figure out if the ECM codes are the same pull it and see what it is, then call and see if that matches what they have, I do know there is a difference in code between 01 and 03 for sure.
(sorry if my tech lingo isn't exactly right)
If you buy a used kenne bell and get the larger injectors they can burn a chip for any year 2v v10, I'm not sure about the 3v's though.
JL
wa-sleeper
11-04-2016 05:14 PM
poocher pup
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
11-03-2010 08:59 PM
