How to replace F-Series 4WD Actuator 1997 - Ford Truck Enthusiasts Forums
Old 01-08-2009, 01:40 PM
CapePowder CapePowder is offline
CapePowder is starting off with a positive reputation.
I have a 97 F250 that I need to replace a sticky front axle 4WD Actuator? Anyone ever do one & can it been done by a someone with some 1/2 decent mechanic skills? Any info and/or directions would be welcomed & appreciated.
Thanks
Bob
Old 01-08-2009, 03:28 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
There's a plastic cover over the actuator. Remove the 3 bolts attaching the cover. The actuator is held in place by an "E-clip". Slide the clip off and work the actuator out of the hole it mounts in. Remove the vacuum lines, noting the position of the colored lines. The difficulty in getting it out of the mounting hole is relative to the corrosion/mud/grease that has accumulated over the years. Installation is the reverse. You're sure it's the actuator and not a broken vacuum line?
View the Technical section of my Gallery for photos of the vacuum actuator system.
http://www.ford-trucks.com/user_gall...&albumid=26547
You can also search my and others posts for troubleshooting and discussions on the subject.
Old 01-08-2009, 04:01 PM
Re: Acuator replacement
Thanks Steve:
I have plenty of vacuum at the acuator motor when it is in 4wd. In fact when I pulled the vacuum line off the acuator to verify vacuum, and then put the vacuum line back on, it went right in to 4wd. But when I go back to 2wd & then try to shift bact to 4wd it does not go in. I got it locked into 4wd right now with cable ties so I can snow plow. But I got to get a replacement acuator. Looks like the diafram is sticking.
Bob
Old 01-08-2009, 04:06 PM
ncranchero's Avatar
ignition actuator shotgun64 1999 to 2016 Super Duty 2 08-26-2015 06:14 AM
04-08 4wd actuator issues Folkles 2004 - 2008 F150 0 03-17-2015 04:21 PM
How do I replace a broken Ignition Actuator Rod for 1997 Ford F150 4x4 Paredez 1997 - 2003 F150 4 06-09-2012 10:03 PM
2002 7.3L Turbo Flutter 02bluemule 1999 - 2003 7.3L Power Stroke Diesel 17 03-05-2012 01:44 PM
Replace Hub Actuator dfboothe 2004 - 2008 F150 5 07-30-2011 08:28 AM
Tags
1997, 1999, 4wd, actuator, actulator, acuator, change, f150, f250, ford, instal, replace, replacement, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
