Best Receiver Hitch Shackle?
Any solid mount will be almost fine. Some are hollow, and these will break.
Now, the problem you have is that you have a Super Duty and that SD is heavy especially when it is stuck.
Where I am going with this is that most shackle mounts will only accommodate the 3/4" bow shackle, and this rather small shackle is only rated to 10,000 lbs.
I gurantee that you will be in excess of this rating if you stick that truck real bad.
I run large trucks, and I am stuck pretty bad once in a while. I find much better results with larger pintle hook type recievers.
Most recovery straps large enough to accomodate trucks this large will not even fit in a small 3/4" bow shackle. So what do you do? You will be foreced to run something larger.
Here is an example:
I use these front and rear:
These permit quick and easy installation of the recovery rope, or strap without damage to either.
Try taking a bow shackle apart and put it back together while it is burried in the mud. Very difficult. These are pretty easy to use.
Here is an example:
How about these:
Trailer Parts Superstore - Pintle Hooks, Mounts & Rings
I think I'll get the 15-ton pintle hook (PH15) and the 2-hole set adapter mount (PM84). I wonder if this is made in China crap or decent stuff?
There are different sizes for these as well. I just searched the web for some images of these. They have the pintle end in ratings up to 20 tons. The reciever is not rated this high so it would be overkill.
Trailer supply places have them, and industrial supply houses have them as well. Use adequate fasteners, and keep it lubed.
They close far enough to accomodate larger ropes and straps and do not destroy the ends.
Many of the big hitters use these out here where I am at. Expect to drop around 80 bucks for this set-up but believe me this is worth it in the ling run.
Here is an image of one being used in the front.
Some may recognoze this truck. It belongs to a buddy of mine, (Rob) and this was taken after his photo shoot for the magazine, but gives you a decent view of this style of recovery point:
If I was still using the stock receiver hitch I wouldn't have any worries - it's a class 5 rated for 15k (I think). I had to take it off for my aftermarket bumper which is a Tough Country 4" sch 40 pipe that bolts to the frame (4 bolts). I'll check the welds on the receiver built into the bumper but I know it isn't rated for what the factory receiver is.
Yes, it made the cover. I can tell you guys that there is more to come. This big ford is only the beginning! You should hear this giant thing. Almost makes my pumpkin seem small. (Almost!) Rob is a cool cat, and he was conservative in the writeup.
You can expact to see more of this large truck in a few future issues. This I can tell you for a fact.
Little off topic here, but you will be able to read more about this vehicle.
This truck is similar to the vehicles that we wheel with on a weekly basis. We have some reasonably cool trucks out here.
Wait till you see the big trux with 49's and 54's. They have license plates too! same mag has been out here documenting our weekly activities.
Robs truck was only one example of a local truck. Looks a little rough I know, but it is still beautiful to me........You have to see this fool drive this thing!
Fear is not an option for him.
1L243
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
19
08-24-2013 11:07 AM
Steve_Uzi
11-20-2000 06:03 PM
