Accel vs. OEM ignition coils, worth changing?
I recently bought a '94 Bronco with a stock 302 EFI. I've had good experiences in the past in other cars when installing oil-filled Accel ignition coils. Now, for the 302 that comes with a dry coil, is it worth the replacement of the OEM coil with the Accel one in terms of fuel savings and acceleration?. Thanks... I ask since the Accel coil is rather expensive down here...
1994 Bronco XLT 5.0L E4OD 3.08 Gasoline/Compressed Natural Gas (Circa Dec, 2008)
1992 Bronco XLT 4.9L C-6 3.08 4x2 Venezuelan CKD (2001 - 2005)
on
The stock coil is strong enough to induce arcing between wires if they are not routed properly, so more voltage may actually hurt performance. But... the stock coils are also prone to breaking down and becomming susceptable to moisture, so if the aftermarket coil eliminates that probelm then it could be considered an upgrade.
FatherDonald74
18
06-16-2014 12:08 PM
oldblue89
36
11-25-2010 05:23 PM
